  3. converting a text to a shape
  • State Verified Answer
  • Views 6204
masamasa
masamasa over 2 years ago
hello
is there a way to convert a text to a shape?
regards
masa
  • DavidJHutchins
    DavidJHutchins over 2 years ago in reply to jc teyssier +1 verified
    The documentation for the axlText2Lines function has the following example code ( which I slightly modified ) text = ashOne("TEXT") lines = axlText2Lines(text) layer = text->layer ; flatten list flattened…
  • DavidJHutchins
    DavidJHutchins over 2 years ago in reply to masamasa +1 verified
    copy <installdir>//share/pcb/examples/skill/ash-fxf/ashone.il locally & then load it into Allegro or APD
  • jc teyssier
    0 jc teyssier over 2 years ago
    Not directly.
    I will use Manufacture->Drafting->Create Detail
    This create lines
    Then this to obtain a shape:
    community.cadence.com/.../ceonverting-a-cline-to-a-shape
  • DavidJHutchins
    +1 DavidJHutchins over 2 years ago in reply to jc teyssier
    layer = text->layer
    ; flatten list
    flattened = foreach( mapcan x lines x)
    foreach(path flattened
       ; may return multiple polys
       polys = axlPolyFromDB(path ?endCapType 'ROUND ?line2poly t)
       ; create shapes in database
       foreach(poly polys
         i = axlDBCreateShape(poly t layer nil nil)
  • masamasa
    0 masamasa over 2 years ago in reply to DavidJHutchins
    thank u, david as always.
    i get this error message
  • DavidJHutchins
    +1 DavidJHutchins over 2 years ago in reply to masamasa
  • masamasa
    thank u so much, david.
    i was able to convert it.
    regards
    masa
