  3. Dynamic Shape no clearance with other elements
  • State Suggested Answer
  • Answers 1
  • Views 5672
xmlee
xmlee over 2 years ago
My board has 12 layers. 4 layers of them can't be poured copper correctly.
In the normal layer, the copper has correct clearance with pins/clines/vias:
While in the abnormal layer, the copper only have clearance at the edge of the shape:
I can confirm they are dynamic copper
And the shape parameter has been set to smooth, no exception overrides:
The 4 problematic layers have conductor layers and plane layers.
In the constraint manager, they have same spacing settings:
How can I resolve this?
  • avant
    0 avant over 2 years ago
    Go into the cross section editor and make sure these are not set as negative planes.
  • xmlee
    0 xmlee over 2 years ago in reply to avant
    Both positive & negative layers showed the same problem, two GND, one PWR and one signal layer.
  • xmlee
    0 xmlee over 2 years ago in reply to xmlee
    Just tried created 4 new layers to replace these problematic layers. It is resolved and I don't know why.
