  3. ROUTE TRACES AT 22.5 DEGREES
  • State Suggested Answer
  • Answers 1
  • Views 6632
gianmarcosh
gianmarcosh over 2 years ago
Is there any option (or SKILL procedure) that allows traces to be routed at 22.5 degrees?
The Add Connect command allows "any angle" routing, but it is difficult to mantaint exactly 22.5 degrees. The Route offset isn't of any help as well.
Any advice is well accepted.
Gianmarco
  • DavidJHutchins
    DavidJHutchins over 2 years ago in reply to DavidJHutchins +1 suggested
    Below is the new skill code: procedure(displayXcursor(@optional (angle "22") (radius "1000")) let((units DataList X Y Z r_path) (units = car((axlDBGetDesignUnits))) unless(atof(angle) (angle = "22")…
  • DavidJHutchins
    0 DavidJHutchins over 2 years ago in reply to gianmarcosh
    I had the same issue with registering the command
    as a workaround I used the following:
    funckey dx 'skill (displayXcursor)'
    So while in 'add connect' I just type 'dx' & get the cursors
