  3. ROUTE TRACES AT 22.5 DEGREES
  • State Suggested Answer
  • Answers 1
  • Views 6632
gianmarcosh
gianmarcosh over 2 years ago
Is there any option (or SKILL procedure) that allows traces to be routed at 22.5 degrees?
The Add Connect command allows "any angle" routing, but it is difficult to mantaint exactly 22.5 degrees. The Route offset isn't of any help as well.
Any advice is well accepted.
Gianmarco
  • DavidJHutchins
    DavidJHutchins over 2 years ago in reply to DavidJHutchins +1 suggested
    Below is the new skill code: procedure(displayXcursor(@optional (angle "22") (radius "1000")) let((units DataList X Y Z r_path) (units = car((axlDBGetDesignUnits))) unless(atof(angle) (angle = "22")…
  • DavidJHutchins
    0 DavidJHutchins over 2 years ago
    Before 'Route offset' was added, I wrote a small skill code routine to display an 11 degree cursor in an X pattern.
    The user would use a funykey to display it multiple times while in 'add connect'
  • gianmarcosh
    0 gianmarcosh over 2 years ago in reply to DavidJHutchins
    Hello David,
    Thanks for your reply. Would you share the script source code?
  • DavidJHutchins
    I am no longer employed by Intel, so I don't have access to that skill code Disappointed
    I will attempt to write an equivalent after I get back from a doctor  appt...
  • DavidJHutchins
    0 DavidJHutchins over 2 years ago in reply to DavidJHutchins
    unless(atof(angle)
    (angle = "22")
    (angle = atof(angle))
    unless(atof(radius)
    cond(((units == "mils")
    (radius = "1000")
    ((units == "inches")
    (radius = "1.0")
    ((units == "microns")
    (radius = "25400.0")
    ((units == "millimeters")
    (radius = "25.4")
    ((units == "centimeters")
    (radius = "2.54")
    (radius = atof(radius))
    (angle = (angle * (3.14159265359 / 180.0)))
    ; X axis
    (X = (radius * cos(angle)))
    (Y = (radius * sin(angle)))
    ;(axlMsgPut "radius %f angle %f X %f Y %f" radius angle X Y)
    (Z = Y * -1.0)
    axlClearDynamics()
    (r_path = axlPathStart(list(X:Z X:Y) 0)) ; 1
    (X = X * -1.0)
    (r_path = axlPathLine( r_path 0 X:Z)) ; 2
    (r_path = axlPathLine( r_path 0 X:Y)) ; 3
    (X = X * -1.0)
    (r_path = axlPathLine( r_path 0 X:Z)) ;4
    axlAddSimpleMoveDynamics(0:0 r_path "path" ?ref_point 0:0)
    ; Y axis
    (Y = (radius * cos(angle)))
    (X = (radius * sin(angle)))
    ;e(axlMsgPut "radius %f angle %f X %f Y %f" radius angle X Y)
    (Z = X * -1.0)
    (r_path = axlPathStart(list(Z:Y X:Y) 0)) ; 5
    (Y = Y * -1.0)
    (r_path = axlPathLine( r_path 0 Z:Y)) ; 6
    (r_path = axlPathLine( r_path 0 X:Y)) ; 7
    (Y = Y * -1.0)
    (r_path = axlPathLine( r_path 0 Z:Y)) ;8
    axlCmdRegister("displayXcursor" 'displayXcursor ?cmdType "interactive")
    Below is an example of calling it while running 'add connect'
  • gianmarcosh
    The code of the procedure actually draws the cursors. However, as soon as I wrap the code in the procedure and register the command, it does not work anymore. I have to debug the problem.
    Anyway, I got the idea, you have been very helpful David!!!
