  3. multiple drill holes on a single padstack
  • State Suggested Answer
  • Replies 7
  • Answers 1
  • Subscribers 166
  • Views 7708
masamasa
masamasa over 2 years ago
hello
how would u define a drill diameter if the padstack has two or more different drill diameters as shown below?
there is only one drill diameter that can be specified on a padstack.
regards
masa
  • excellon1
    0 excellon1 over 2 years ago
    Hi Masa
    Each throughole padstack can only contain one drill size,  this is because the drill size will map to a Tool in a physical drilling machine that will drill the board.
    When doing a HDI based board it is possible to select different vias with different drill sizes for a given layer pair and then generate a seperate drill file for each of the
    layer pairs.
    It looks to me in your picture what your referencing is a board that uses blind and burried vias ?, Maybe you can clarify that.
    Best Regards.
  • masamasa
    0 masamasa over 2 years ago in reply to excellon1
    thank u for ur response.
     sorry for confusion.
    yes, i am talking about blind vias
    regards
    masa
  • masamasa
    0 masamasa over 2 years ago in reply to masamasa
    today cadence visited us and i directly asked this question to them.
    they suggested i create a structure of two different padstacks as a symbol.
    creating a structure works somehow.
    i did not have time to discuss further with cadence but i wonder how to replace the two padstacks with the symbol created.
    regards
    masa
  • steve
    0 steve over 2 years ago in reply to masamasa
    Look at the command Route - Structures - Replace Via with Structure...
  • excellon1
    0 excellon1 over 2 years ago in reply to masamasa
    Hi MasaMasa it's interesting they suggested a via structure to you, certainly it is possible to use via structures but there is alot of baggage associated with this. Normally doing blind and burried vias one would have a choice of vias to use for a given layer pair
    setup in advance, that way you could easily just change the via you wish to use, similar to how it can be done if doing a standard board.
    When doing BB Vias in Cadence the via is based on a standard throughole via you have defined and that means one drill size only.
    the difference with BB vias is your standard via gets modified so it only will span the layers of interest and in addition to this a drill file for that layer pair can be created.
    Even with via structures you're still looking at using a standard via with one drill size for that via, not multiple selectable drill sizes unless something has changed that I am not aware of with respect to tooling assignments. The via structure does have advantages in certain areas though such as including etch. Can be useful for things like diffpairs, fanouts etc.
    I think probably the easiest solution for you is to just create a set of vias with different drill sizes you wish to use. The vias could be the same physical size too with just a different drill. Changing the via on the fly is simple too.
    Best Regards.
