  3. How to Add via array for oblong shapes pad
  • State Suggested Answer
  • Answers 1
  • Subscribers 169
  • Views 6379
RohitRohan
RohitRohan over 2 years ago
Dear Community,
I am currently working on adding a via array around an oblong-shaped pad. While I have successfully implemented via arrays across the board and around circular pads, I am facing challenges in configuring the via array to surround the oblong-shaped pad.
Could anyone please provide guidance or suggestions on how to achieve this configuration?
Rohit Rohan
  • techiecs
    techiecs over 2 years ago +1 suggested
    To add a via array around an oblong-shaped pads- 1 Go to Place>Via Array command. 2 Enable Pins in the Find filter. 3 In the Options panse, set the Array parameters type to 'Surrounding' and set other…
  • techiecs
    0 techiecs over 2 years ago
    3 In the Options panse, set the Array parameters type to 'Surrounding' and set other parameters.
    4 Click on the oblong pad to see the preview of the via array.
    5 Once you are fine with the pattern shown, click anywhere on the design canvas to place the via array around the oblong pad selected.
  • bedroomposse
    0 bedroomposse over 2 years ago
    The via array is not displaying as I expected, what should I do?
    planet clicker
  • bedroomposse
  • techiecs
    0 techiecs over 2 years ago in reply to bedroomposse
    When you click on the oblong pad to see the preview of the array, and if the pattern is not as you are expecting it to be, then you can change the parameters in the options pane as per your requirement, and after that you can see if it as per your expectation.
