  3. Copy cline to solder mask layer
  • State Verified Answer
  • Answers 1
  • Subscribers 167
  • Views 7524
Fredda
Fredda over 2 years ago
I want to make an opening in the solder mask right above a trace that is acting like a guard ring. Do I really need to go and buy the Allegro Productivity Toolbox add-on for using the Cross-Copy tool for a basic operation like that??
/F
  • steve
    steve over 2 years ago +1 verified
    There is a new command in 24.1 under the Shape menu called Void Adjacent Layer Shapes that should be able to do what you want available in all license levels.
  • excellon1
    excellon1 over 2 years ago +1 verified
    As Steve suggested the new shape feature to handle this works well so if you are on the latest release you can try that out. Other methods do exist if not on latest. You could simply draw in the soldermask…
  • Fredda
    Fredda over 2 years ago in reply to steve +1
    Thanks. Great, I'll try that the next time! I ended up drawing a shape instead of a cline for the guard ring. And a shape is easy to copy to any layer. /F
  • steve
    0 steve over 1 year ago in reply to RohitRohan
    Hi Rohit
    Take a look at this:- How to create voids for critical signals in adjacent layer shapes
