  3. netlist file type
  • State Verified Answer
  • Subscribers 159
  • Views 3176
netlist file type
masamasa
masamasa 10 months ago
hello:
is there a way to export a netlist as a csv file?
i always export it as a text file as shown below.
regards
masa
  • Hoangkhoipcb
    0 Hoangkhoipcb 10 months ago
    Hi masa!
    you can type cmd like this.
    skill fprintf(outfile("./net_list.txt" "w") "%s\n" buildString(axlDBGetDesign()->nets~>name "\n") t)
    and then see the name "net_list.txt" file.
    HoangKhoi.
  • masamasa
    0 masamasa 10 months ago in reply to Hoangkhoipcb
    thank u for ur response, hoangkhoi:
    unfortunately it is still a text file, not a csv file.
    regards
    masa
  • Hoangkhoipcb
    0 Hoangkhoipcb 10 months ago in reply to masamasa
    Masa . try again this cmd:
    skill fprintf(outfile("./net_list.csv" "w") "%s\n" buildString(axlDBGetDesign()->nets~>name ",") t)
  • DavidJHutchins
    +1 DavidJHutchins 9 months ago in reply to Hoangkhoipcb
    below is a skill routine to output a netlist csv file...
    procedure((csv_net_export @optional FileName)
       prog((fptr OutputName NetCnt)
            if( FileName then
                (OutputName = strcat(simplifyFilename(".") "/" FileName))
                (OutputName = FileName)
            else
                (OutputName = strcat(simplifyFilename(".") "/netlist.csv"))
            if(isFile(OutputName) then
               unless(deleteFile(OutputName)
                   (axlMsgPut "ERROR: could not remove existing file %s" OutputName)
                   return()
            if((fptr = outfile(OutputName)) then
                (NetCnt = 0)
                foreach(Net (axlDBGetDesign()->nets)
                    (NetCnt++)
                    foreach(Branch (Net->branches)
                        foreach(Child (Branch->children)
                            if(((Child->objType) == "pin") then
                                fprintf(fptr "%s,%s,3,4,5,6,7,%s\n" Child->component->name Child->number Net->name)
                close(fptr)
                (axlMsgPut "%d nets written to %s" NetCnt OutputName)
            else
                (axlMsgPut "ERROR: could not open output file %s" OutputName)
  • Hoangkhoipcb
    0 Hoangkhoipcb 9 months ago in reply to DavidJHutchins
    Hi DavidJHutchins!
    it works for me. Thank you
    Regards.
    HoangKhoi
