  3. importing gerber data
  • State Suggested Answer
  • Answers 1
  • Views 5608
masamasa
masamasa over 1 year ago
hello:
after importing gerber file into a design file, how can i assign a net into the imported shapes and clines?
there is no net assigned to a shape after the gerber file import although the vias connected to the shape have a net.
i have over 10k shapes and clines on my design.
regards
masa
  • avant
    0 avant over 1 year ago
    Have you tried moving the shape (ix 0)? It seems like the shape should inherit a net of a via after you pick it and drop it back down.
  • DavidJHutchins
    0 DavidJHutchins over 1 year ago in reply to avant
    I would try:
    derive connectivity lines
  • Hoangkhoipcb
    0 Hoangkhoipcb over 1 year ago
    Hi masa!
    Can you show me some pictures?
    Best Regaurds.
    HoangKhoi.
  • masamasa
    0 masamasa over 1 year ago in reply to Hoangkhoipcb
    thank u for ur response, hoangkhoi
    somthing like this.
    regards
    masa
  • Hoangkhoipcb
    0 Hoangkhoipcb over 1 year ago in reply to masamasa
    Hi Masa!
    You can refer this code:
    Fullscreen code3.txt Download
    axlCmdRegister("change_net_trace" `change_net_trace )
    (defun change_net_trace ()
    	cmd_str_list = nil
    	ori_vis = axlVisibleGet()
    	axlVisibleDesign(nil)
    	axlVisibleLayer("VIA CLASS" t)
    	axlClearSelSet()
    	axlSetFindFilter(?enabled '(noall VIAS NAMEFORM) ?onButtons '(noall ALL))
    	axlAddSelectAll()
    	via_list = axlGetSelSet()
    	axlVisibleSet(ori_vis)
    	axlClearSelSet()
    	axlSetFindFilter(?enabled '(noall CLINES SHAPES NAMEFORM) ?onButtons '(noall ALL))
    	mypopup = axlUIPopupDefine(nil (list (list "Done" 'axlFinishEnterFun) (list "Cancel" 'axlCancelEnterFun)))
    	axlUIPopupSet( mypopup)
    	axlSelect(?prompt "Please select an element...")
    	select_list = axlGetSelSet()
    	axlClearSelSet()
    	foreach(item select_list
    		sub = cadr(parseString(item->layer "/"))
    		if(item->objType == "path" then
    			cline = item
    			st_clines = cline->segments~>startEnd
    			st_seg = car(cline->segments)->startEnd
    			tmp = length(setof(e st_clines member(car(st_seg) e) != nil))
    			if(tmp == 2  then
    				st_seg = reverse(st_seg)
    			last_seg = lastelem(cline->segments)->startEnd
    			tmp = length(setof(e st_clines member(car(last_seg)  e) != nil))
    			if(tmp == 2  then
    				last_seg = reverse(last_seg)
    			poly = car(axlPolyFromDB(car(cline->segments) ?endCapType 'ROUND))
    			via = car(setof(e via_list axlPadOnLayer(e  strcat("ETCH/" sub)) == t && axlGeoPointInShape(e->xy poly nil) == t))
    			cmd_str_list = cons( sprintf(nil "pick %f %f; pick %f %f" xCoord(car(st_seg)) yCoord(car(st_seg)) xCoord(via->xy) yCoord(via->xy)) cmd_str_list)
    			poly = car(axlPolyFromDB(lastelem(cline->segments) ?endCapType 'ROUND))
    			cmd_str_list = cons( sprintf(nil "pick %f %f; pick %f %f" xCoord(car(last_seg)) yCoord(car(last_seg)) xCoord(via->xy) yCoord(via->xy)) cmd_str_list)
    		else
    			vias = nil
    			if(item->shapeBoundary == nil then
    				poly = car(axlPolyFromDB(item ?endCapType 'ROUND))
    				vias = setof(e via_list e->net->name != "" && axlPadOnLayer(e  strcat("ETCH/" sub)) == t && axlGeoPointInShape(e->xy poly nil) == t )
    			else
    				poly = car(axlPolyFromDB(item->shapeBoundary ?endCapType 'ROUND))
    				if(poly->holes != nil then
    					foreach(hole poly->holes
    						vias = setof(e vias axlGeoPointInShape(e->xy car(axlPolyFromHole(hole)) nil) == nil )
    			if(vias != nil then
    				via = car(vias)
    				axlChangeNet(item via->net)
    	if(cmd_str_list != nil then
    		axlShell("setwindow pcb; prepopup 0.0 0.0; done")
    		axlCmdRegister("_slide_seg" `_slide_seg ?cmdType "general")
    		axlShellPost("_slide_seg")
    (defun _slide_seg ()
    		axlShell("setwindow pcb; slide; setwindow form.find; FORM find all_off ; FORM find cline_segs YES ; FORM mini allow_errors YES;")
    		foreach(cmd cmd_str_list
    			axlShell(cmd)
    		axlCmdUnregister("_slide_seg")
    		axlShell("setwindow pcb; done;change_net_trace")
    Regards.
    HoangKhoi.
