  3. merging nets
  • State Verified Answer
  • Subscribers 166
  • Views 5814
merging nets
masamasa
masamasa over 1 year ago
hello:
i have a design already made by someone.
now i have to merge net a and net b as net c on the design.
what would be the easiest way to merge two nets where shapes, clines, vias, symbols are already assigned as net a and net b?
regards
masa
  • mahimag
    mahimag over 1 year ago +1 verified
    Hello masamasa , You can use Logic > Net Logic to create or assing new nets. I have also written a sample code few days back, see if this helps you: axlCmdRegister("merge_net" '_RBG_change_shape_net )…
  • Siliconmaster
    Siliconmaster over 1 year ago +1
    May be placing a zero ohm resistor in between can help
  • mahimag
    +1 mahimag over 1 year ago
    axlCmdRegister("merge_net" '_RBG_change_shape_net ) defun( _RBG_change_shape_net () let( list(old_netname new_netname l_shapes shape_count)
    old_netname = "LED1" ;name of net to remove
    new_netname = "0" ;name of combined nets
    obj_count = 0
    axlClearSelSet()
    axlSetFindFilter(?enabled '(noall "shapes" "vias" "pins") ?onButtons
    '("shapes" "vias" "pins"))
    axlAddSelectAll()
    l_obj = axlGetSelSet()
    axlClearSelSet()
    foreach(obj l_obj
    if(obj->parent->net->name == old_netname then axlChangeNet(obj new_netname) obj_count++ );this if will work for shapes and vias
    if(obj->net->name == old_netname then axlChangeNet(obj new_netname) obj_count++ );this if will work for pins
    );end foreach
    if(obj_count>0 then
    printf("%n objects changed from %s to %s.\n" obj_count old_netname
    new_netname)
    else
    printf("No obj found connected to net %s\n"
    old_netname)
    );endif
    );end let
    );end defun
    ; you need to change the old_netname and new_netname based on your design.
  • excellon1
    0 excellon1 over 1 year ago
    Hi Masa,
    When creating the new netlist un check the option " Allow etch removal during eco"
    Best Regards.
  • Siliconmaster
    0 Siliconmaster over 1 year ago
  • masamasa
    0 masamasa over 1 year ago in reply to mahimag
    thank u very much.
    it works perfectly.
    i did not know that the net name is case sensitive, though.
    regards
    masa
