  3. How to get a report showing padstack (and shapes used in...
  • State Suggested Answer
  • Replies 8
  • Answers 2
  • Subscribers 166
  • Views 7673
How to get a report showing padstack (and shapes used in it) library path ?
jc teyssier
jc teyssier over 1 year ago
Hello group,
in my company the padpath and psmpath can be customized for each project: doing this allow to have different copper annular ring and soldermask opening depending on project seting
For verifications purpose, i need to get a report showing:
- From where padstacks was taken on disk (show element on a pin ou via show ,the related library path, as per symbols but it is not really a report).
- From where the shapes used in padstack was taken on disk.
Someone have idea about to get this?
Jean-Charles
  • mahimag
    mahimag over 1 year ago +1 suggested
    Hello jc teyssier , You can have a look at Padstack Usage Report which can give you library path for each pad file
  • JCTEYSSIER0
    0 JCTEYSSIER0 over 1 year ago in reply to steve
    Thanks steve: this is exactly what i need and it works Slight smile
  • JCTEYSSIER0
    0 JCTEYSSIER0 5 months ago in reply to steve
    Hello Steeve,
    sorry for undig this tread.
    my skill langage programming level is pretty low.
    Do you think this skill cna be enhanced to extract also module's source path?
    Embended allegro "module report" does not show it.
    It shows only Module instanec, module definito, x and y coordonate and angle. I wish to het source path
  • steve
    0 steve 5 months ago in reply to JCTEYSSIER0
    Sorry but I'm unaware of the skill required for the module report. Hopefully someone else may be able to modify the orignal skill that is included in this post earlier to give you what you need,
