  3. How to get a report showing padstack (and shapes used in...
  • State Suggested Answer
  • Replies 8
  • Answers 2
  • Subscribers 166
  • Views 7667
How to get a report showing padstack (and shapes used in it) library path ?
jc teyssier
jc teyssier over 1 year ago
Hello group,
in my company the padpath and psmpath can be customized for each project: doing this allow to have different copper annular ring and soldermask opening depending on project seting
For verifications purpose, i need to get a report showing:
- From where padstacks was taken on disk (show element on a pin ou via show ,the related library path, as per symbols but it is not really a report).
- From where the shapes used in padstack was taken on disk.
Someone have idea about to get this?
Jean-Charles
  • mahimag
    mahimag over 1 year ago +1 suggested
    Hello jc teyssier , You can have a look at Padstack Usage Report which can give you library path for each pad file
  • mahimag
    0 mahimag over 1 year ago
  • jc teyssier
    0 jc teyssier over 1 year ago in reply to mahimag
    this is ok for padsatcks.
    What about shapes (.ssm) ?
  • mahimag
    0 mahimag over 1 year ago in reply to jc teyssier
    this you can get in padstack definition report, there is a column for Shape Name
  • JCTEYSSIER0
    0 JCTEYSSIER0 over 1 year ago in reply to mahimag
    i do not need the name (well, i also need in order to find the path) but the path from where where find the .ssm file, here LTUMODULEPIN1SM.ssm
    In my library several definition exist for same shape name ; the path to use the right shape is project dependant (example: distance from soldermask to copper). I need to get this path for quality control purpose.
  • steve
    0 steve over 1 year ago in reply to JCTEYSSIER0
    https://community.cadence.com/cfs-file/__key/communityserver-discussions-components-files/28/show_5F00_libraryV2.zip
    Give this skill a try. Runs a report which should list what you need.
