  3. replacing padstacks
  • State Suggested Answer
  • Answers 1
  • Views 4361
replacing padstacks
masamasa
masamasa over 1 year ago
hello:
a drc check is required during the replacing padstack command as default.
i have many padstacks to be replaced on my design and each time i do it, i do not want the drc check.
is there a way to omit the drc check each time i replace padstacks?
regards
masa
  • John T
    0 John T over 1 year ago
    Hi Masa, we can confirm as the tool indicates, that it is must to run DRC check for any physical changes and changing Via is one example. Therefore Batch DRC will not occur for all Padstack-type changes. The Batch DRC will be used on any change classified as a physical change. This is required because this is a forced change and can potentially cause a serious DRC condition at some locations. I hope this provides a sufficient reason for having a Batch DRC as a compulsory operation and why it cannot be turned off.
