  3. Edit Copper Shape Boundary
  • State Suggested Answer
  • Answers 2
  • Subscribers 166
  • Views 5264
BaldEngineer
BaldEngineer over 1 year ago
Hi
I am trying to change the Copper shape boundary to let us say 30 degrees.
But the only option i am getting under segment type is Line, Line 45, Line Orthogonal.
  • jc teyssier
    0 jc teyssier over 1 year ago
    in such case i will not modify the shape but decompose it in order to obtain lines. Line are easier to manipulate.
    You can move them and give them an angle (command angle for absolute angle or iangle for relative angle)
    While you are satisfied of the boundary you compose shape with the lines.
  • steve
    0 steve over 1 year ago
    When drawing the shape you can use Shape - Polygon then set the segment type to just a line (which is any angle line), then pick your starting point, now type polar in the command line and a popup will allow you to set the distance (it says radius but it's the length of the line you are adding), the popup the asks for the angle, the line is then added at this location. Type polar to add the next part of the line.
  • jc teyssier
    0 jc teyssier over 1 year ago in reply to steve
    Thank you Steve: i forget this polar command since i have not used it since.... i can not remember
    You refresh my memory
