  3. Allegro X 23.1 Free Physical Viewer, can you 'Flip Design...
  • State Verified Answer
  • Views 4356
Allegro X 23.1 Free Physical Viewer, can you 'Flip Design'?
mikentucson
mikentucson over 1 year ago
I've been using Allegro Free Physical Viewer 17.4, which has the -View 'Flip Design' ability.  I don't see this option in Allegro X 23.1 Free Physical Viewer.
Is it possible to 'Flip Design' in Allegro X 23.1 Free Physical Viewer?
  • oldmouldy
    oldmouldy over 1 year ago +1 verified
    In the Visibility panel, View>Visibility if it isn't displayed, there are Layers and Display options, In Display there is View From Top / Bottom.
  • DavidJHutchins
    DavidJHutchins over 1 year ago +1 verified
    enable the command window using 'View>Command' Then at the Command> prompt enter 'flipdesign'
  • techiecs
    0 techiecs over 1 year ago
    I also checked this at my end and I could not see View>Flip Design menu in 23.1 Allegro free viewer.
    I'm not sure from which version did this Flip menu menu gone missing in the Allegro Free Viewer.
    You mentioned that it was there in 17.4 , maybe I'll check in 22.1 version as well.
  • oldmouldy
    +1 oldmouldy over 1 year ago
  • DavidJHutchins
    +1 DavidJHutchins over 1 year ago
  • mikentucson
    0 mikentucson over 1 year ago in reply to oldmouldy
    Ah yes, I found the button to toggle between Top/Bottom.  Thank you!
  • mikentucson
    0 mikentucson over 1 year ago in reply to DavidJHutchins
    Yes that works!  Thank you!
