  3. Analysis modes are locked in Constraints Manager
  • Replies 9
  • Views 8199
SnopDog
SnopDog over 1 year ago
How to unlock possibility to switch on/off analysis modes? I can't change the state of the checkboxes in the Analysis Modes in Constraint Manager.
I wanted to add a rule in the constraints manager regarding minimum spacing between the outline and the pads
I can add new CSET but it is always "yellow" which means that is not "switched on". When I go to Analyze -> Analysis Modes I can't change anything.
I have looked for entry in "env" file or to run the Allegro in safe mode but no luck.
  • steve
    0 steve over 1 year ago in reply to SnopDog
    OK Can you close the tools, open a Windows File Explorer and type %HOME% followed by a return into the address bar followed by a return. This opens your HOME folder (usually C:\SPB_Data or simlar). In here rename the pcbenv folder to pcbenv_old. Then restart the tools and try again. If this works you may need to redefine your library paths and other shortcut keys you have in the env file, if it doesn't delete the new pcbenv folder created and rename the pcbenv_old back to pcbenv.
  • SnopDog
    0 SnopDog over 1 year ago in reply to steve
    I also made one change to Defined Variables and it's seen under Tools-Utilities-Env Variables
    "set retain_electrical_constraints_on_nets = NO"
    and no result :-(
    I looked at all my *.cpm files for "set retain_electrical_constraints_on_nets = YES" but no hits found.
    I deleted the pcbenv file - no positive result.
    I also ran Allegro in safe mode - no positive result.
    Can it be a setting in registry?
  • steve
    I don't think there is a registry setting for this but you maybe have to ask Cadence via the support site. What happens if you try a new blank board (File - New) then before you do anything try the constraint modes. If that's OK are the constraints controlled in the front end (DEHDL or System Capture). Do you have a site.cpm set? Is there anything there? Are there other users with the same issue?
  • SnopDog
    I noticed a thing in allegro.jrl file which records all you do in the project.
    \i (00:20:32) QtSignal m_dockWsQtWidgetContents m_domainSelector currentChanged Manufacturing
    \i (00:20:32) QtSignal m_domainSelector WS_Manufacturing itemSelectionChanged "Design for Assembly" +
    \i (00:20:32) QtSignal "DFA Constraint Set" Outline
    \i (00:20:32) QtSignal Frozen_All_Layers_WorksheetView174 Frozen_All_Layers_WorksheetView174Header sectionMoved +
    \i (00:20:32) QtSignal 0 0 1
    \i (00:20:32) QtSignal 1 1 0
    \i (00:20:32) QtSignal All_Layers_WorksheetView174 All_Layers_WorksheetView174Header sectionMoved +
    Many times the Frozen is there whenever I tried to change the status in Checkboxes. Maybe this is the direction where we should look for solution?
    I look inside the *.cpm file there is nothing weird there.
    I also ran "dbdoctor" check the database. Nothing helped.
