  3. Analysis modes are locked in Constraints Manager
  • Replies 9
  • Views 8194
SnopDog
SnopDog over 1 year ago
How to unlock possibility to switch on/off analysis modes? I can't change the state of the checkboxes in the Analysis Modes in Constraint Manager.
I wanted to add a rule in the constraints manager regarding minimum spacing between the outline and the pads
I can add new CSET but it is always "yellow" which means that is not "switched on". When I go to Analyze -> Analysis Modes I can't change anything.
I have looked for entry in "env" file or to run the Allegro in safe mode but no luck.
  • steve
    0 steve over 1 year ago
    It sounds like there is a restriction on the board file. You can lock the design with a password which may restrict Constraint changes. Look at File - Properties - Locking tab and see if there is password control on the board. You would need to get that password to unlock it.
  • SnopDog
    0 SnopDog over 1 year ago in reply to steve
    Unfortunately this is not the case ;-(
    The design is not locked. Moreover I tried with different designs and in the Allegro PCB Editor 17.4 and 23.1 - both with hotfix installed.
  • SnopDog
    0 SnopDog over 1 year ago in reply to SnopDog
    I strongly believe that this is something connected with the registry.
  • steve
    0 steve over 1 year ago in reply to SnopDog
    OK Go to the Computer environment variables and see if there is a preference called retain_electrical_constraints_on_nets with a value of YES. If there is try renaming it to ###retain_electrical_constraints_on_nets to disable it. Then restart Allegro and try again.
  • SnopDog
    Do you mean Environment Variables? I am using Windows 10.
    There is no such variables in my system.
    I also check the system and the user (account) variables.
