  3. How to check short in Gerber file
  • State Suggested Answer
  • Answers 1
  • Views 6069
Filo221
Filo221 over 1 year ago
Hi all,
I ask a help about how check short between nets in gerber files. I would like to able  to check the files that I sent to supplier to PCB.
I try to export ODB++, but in ODB++ Viewer I don't find any command in order to chek.
  • steve
    0 steve over 1 year ago
    Try importing the gerber into a tool such as CAM350, GerbView or Viewmate and give it a try there. In general a DRC check in the board file will report errors such as shorts.
  • Filo221
    0 Filo221 over 1 year ago in reply to steve
    Ok. I already use it, but I want to control gerber files. No brd file.
    For example, Import the  cadence netlist in CAM350, GerbView or Viewmate and to do a check.
    I want to do this because is possible don't have drs error (or not see it) in allegro, but in reality there is the error.
    But in I want to other check on gerber file (production file) in order to intercept these cases.
  • DavidJHutchins
    0 DavidJHutchins over 1 year ago in reply to Filo221
    The ODB++ Viewer is only a viewer, if you want to check anything you need a licensed tool which which are not free...
    Most CAM type tools will require an IPC-D-356 netlist file and the various Nc-drill files besides the Gerber artwork files
  • Filo221
    0 Filo221 over 1 year ago in reply to DavidJHutchins
    Ok. I can valuated buy licensed tool. But I have to understand if it works. For example CAM350 can do it? Is there a tutorial or a document?
  • DavidJHutchins
    Below is an example process that applies to most CAM tools:
    Import the Gerber artwork files in the correct order to match the stackup section of the IPC-D-356 netlist file.
    Import the NC-Drill files, ensure the start & end layers for buried and blind vias are set correctly.
    Import the IPC-D-356 netlist file.
    Run the net-list comparison tool...
