  3. retaining via nets
  • Views 4195
retaining via nets
masamasa
masamasa over 1 year ago
hello:
is there a way to retain via nets when they are moved?
i do know that retaining via nets is possible when they are copied.
i would like to do the same when i move vias with retaining their nets.
regards
masa
  • mahimag
    0 mahimag over 1 year ago
     Hi masamasa , you can add "Retain_Net_On_Vias"  property to the via to retain the nets while moving the vias.
  • masamasa
    0 masamasa over 1 year ago in reply to mahimag
    thank u for ur reply.
    i do not know if i would like to do this as i would not know which vias can retain the nets or not after adding this property.
    regards
    masa
