  3. removing layers
  • State Suggested Answer
  • Answers 1
  • Views 7649
removing layers
masamasa
masamasa over 1 year ago
hello
is there a way to remove a layer even if there r some objects on the layer?
it takes me a whole day to delete objects so i just simply would like to delete the layers with objects attached.
regards
masa
  • techiecs
    techiecs over 1 year ago +1
    We cannot delete a layer if there are objects present on that specific layer. The tool does not allow that and it lists the objects and their location that are present on the layer which are preventing…
  • techiecs
    0 techiecs over 1 year ago
    We cannot delete a layer if there are objects present on that specific layer. The tool does not allow that and it lists the objects and their location that are present on the layer which are preventing it from being deleted. We need to ensure that these objects are removed first from the layers before deleting it.
  • masamasa
    0 masamasa over 1 year ago in reply to techiecs
    hello
    thank u for ur response.
    with skill codes, u can not delete a layer?
    regards
    masa
  • DavidJHutchins
    0 DavidJHutchins over 1 year ago in reply to masamasa
    You need to delete the data on the layer first, then you can delete the layer
    Below is an example of first creating a temporary layer, then deleting the contents of the layer, then deleting the layer:
    (TempLayer = strcat(axlMapClassName("BOARD") " GEOMETRY/MHCS_TEMP"))
    (axlLayerCreateNonConductor TempLayer)
            (axlDeleteByLayer TempLayer 'fixed)
            ;; delete the temp layer
            (data = (axlGetParam sprintf(nil "paramLayerGroup:%s/paramLayer:%s" strcat(axlMapClassName("BOARD") " GEOMETRY") "MHCS_TEMP")))
            axlDeleteObject(data)
  • masamasa
    0 masamasa over 1 year ago in reply to DavidJHutchins
    thank u for ur response, david.
    unfortunately i would like to forcefully remove a layer before removing all objects on the layer i would like to remove.
    sometimes it takes hours to remove all objects manually only on a single layer.
    is there a skill code that can remove all objects on a specified layer?
    regards
    masa
  • DavidJHutchins
    I have not seen any issues deleting large amounts of data using the skill function (axlDeleteByLayer "Class/Subclass")
