  3. Need help regarding Differential Pair Routing on PCB Editor...
  • State Suggested Answer
  • Answers 1
  • Views 5910
Need help regarding Differential Pair Routing on PCB Editor 17.4
ManjunathMysore
ManjunathMysore over 1 year ago
Hi
I'm a newbie, I need suggestions regarding differential pair
I have completed most of my routing on a 4 layer board and not routed the differential pair which I had kept it later to route, but now I'm unable to route the differential pair according to the rules of the differential pairs of USB,Ethernet and CAN protocols as all the above protocols should get reference plane and there should be no single trace passing under the differential pair, but as I have already routed there are many traces which are getting crossed over in different layers.
How can I move forward?
Please suggest
  • Gowtham P
    0 Gowtham P over 1 year ago
    That seems to be a tricky situation.
    If it were me, I would:
    1. Perform some routing cleanups in the areas where the differential pairs need to be routed.
    2. Create constraints in Constraint Manager for the differential pairs (e.g., spacing, width, and reference plane requirements).
    3. Identify rule violations using DRC Check.
    4. Move conflicting traces or reassign them to different layers to avoid overlaps.
    5. Route the differential pairs, ensuring reference plane continuity.
    6. Verify the final routing with a DRC check.
    • Vote Up -1 Vote Down
  • ManjunathMysore
    0 ManjunathMysore over 1 year ago in reply to Gowtham P
    Thank you so much Gowtham
    Will look into it
  • excellon1
    0 excellon1 over 1 year ago
    Hi, if you are out of routing space and time is not on your side just move that 4lyr board to 6lyrs instead.
    There will be a minor cost incursion in volume for a 6lyr board, however from an electrical perspective it should work better as you have more surface
    area  to work with. With the extra layers your power distribution should be better too.
    Best regards.
  • ManjunathMysore
    0 ManjunathMysore over 1 year ago in reply to excellon1
    Thank you so much excellon1
    Will ask the fabricator for the later stack up with respect to
    6 layer
