  3. How to close Form before running another procedure
  • State Verified Answer
  • Views 4908
Dave413
Dave413 over 1 year ago
I have a skill routine that starts by initiating a form with a few radio buttons. Once radio button is selected is the user proceeds by pressing the "Extract" button.
The program will then prompt the user to box select some elements before terminating.
My issue is that the form annoyingly stays open while the user is prompted to box select elements even though in my code, axlFormClose is called before my extractLegacy() procedure.
Any help on this would be much appreciated. Relevant .il code pasted below
David Nguyen
form = '("
FILE_TYPE=FORM_DEFN VERSION=2
FORM
FIXED
PORT 50 50
HEADER \"Parts List Extractor\"
TILE
TEXT \"Script will output parts list extract .txt and pl_compare.xlsm in current .brd directory.\"
TLOC 2 1
ENDTEXT
TEXT \"For Legacy PL extract, PL columns should be selected by relevant group followed by right click Next \"
TLOC 2 3
ENDTEXT
FIELD integral
FLOC 2 8
CHECKLIST \"Integral PL\" \"radio\"
ENDFIELD
FIELD legacy
FLOC 2 10
CHECKLIST \"Legacy PL\" \"radio\"
ENDFIELD
FIELD extract
FLOC 2 12
MENUBUTTON \"EXTRACT\" 9 3
ENDFIELD
FIELD cancel
FLOC 6 12
MENUBUTTON \"CANCEL\" 9 3
ENDFIELD
ENDTILE
ENDFORM
procedure( start_gui()
myForm = axlFormCreate('_mil_myForm list("myform" form) '("msgLines" 0) 'formAction nil nil)
axlFormSetField(myForm "integral" t)
axlFormDisplay(myForm)
procedure( formAction(myForm)
case(myForm->curField
("extract"
isIntegral = axlFormGetField(myForm "integral")
if(isIntegral then
axlFormClose(myForm)
extractIntegral()
else
extractLegacy()
);end if
("cancel"
); end case
); end procedure
  • Hoangkhoipcb
    Hoangkhoipcb over 1 year ago +1 verified
    Hi David Nguyen! Can you refer this solution. Best Regard. HoangKhoi.
  • Hoangkhoipcb
    +1 Hoangkhoipcb over 1 year ago
    Hi David Nguyen!
    Best Regard.
    HoangKhoi.
  • Dave413
    0 Dave413 over 1 year ago in reply to Hoangkhoipcb
    Thanks Hoang, this worked!
