  3. Schematics and PCB don't seem properly linked
  • State Verified Answer
  • Views 4529
AL202512303326
AL202512303326 over 1 year ago
I got handed over a PCB project, I have the parts libraries, schematics and the PCB. The PCB and schematics seem to only semi-correspond to each other: I can cross-probe all nets that I tried, didn't try them all) and some components, but not all of them. So I tried to sync up the SCH and the PCB, and no matter what I tried, around 180 components would always disappear from the board and would have to be placed manually again. At the same time, some of the constraints (most notably, for routing diff. pairs) would stop working. The same thing happens if I try to use the Update PCB button, or if I export a netlist from the SCH and import into the PCB. I can see no logic as to which components disappear (they are not the same ones as the ones I cannot cross-probe), but it's always the same amount, and always the same ones.
The closest I got to stuff not going whack is by fixing/locking a few components I know would disappear, and then trying to update the PCB while unticking the "ignore FIXED propery" checkmark. In this case, the update wouldn't happen, and I would get thrown a message saying "Error processing 'C101': Cannot modify element; the object or a parent has the FIXED property.", then "Run stopped because errors were detected", then the whole process, well, stopping.
Any tips as to why this might happen? Maybe some file got missed in the handover (it was remote, I just got handed a bunch of stuff), and I should ask for it?
TRANSLATE with x
English
Arabic Hebrew Polish
Bulgarian Hindi Portuguese
Catalan Hmong Daw Romanian
Chinese Simplified Hungarian Russian
Chinese Traditional Indonesian Slovak
Czech Italian Slovenian
Danish Japanese Spanish
Dutch Klingon Swedish
English Korean Thai
Estonian Latvian Turkish
Finnish Lithuanian Ukrainian
French Malay Urdu
German Maltese Vietnamese
Greek Norwegian Welsh
Haitian Creole Persian
TRANSLATE with
COPY THE URL BELOW
Back
EMBED THE SNIPPET BELOW IN YOUR SITE
Enable collaborative features and customize widget: Bing Webmaster Portal
Back
  • avant
    avant over 1 year ago in reply to AL202512303326 +1 verified
    One thing that may be a quick fix is to export the component placement file, import the netlist, and then import the component placement file.
  • avant
    0 avant over 1 year ago
    When importing the netlist, make sure the "always place changed component' box is checked.
    I noticed this starting with Allegro version 17.4
  • AL202512303326
    0 AL202512303326 over 1 year ago in reply to avant
    Sadly that didn't solve the problem, I still have the same components misbehaving. I also tried placing a few of them, then re-importing the netlist, and the same components disappeared again.
    TRANSLATE with x
    English
    English Korean Thai
    French Malay Urdu
    TRANSLATE with
    COPY THE URL BELOW
    Back
    Back
  • avant
    +1 avant over 1 year ago in reply to AL202512303326
  • AL202512303326
    Yep, that worked. Not sure what's causing the issue, but this workaround saved me so much headache! Thank you!
