  3. null padstack
  • Views 3750
null padstack
masamasa
masamasa over 1 year ago
hello
is there a way to find the locations of null padstacks?
i accidentally made a padstack to a null padstack before removing its net from the padstack on a symbol.
now the unconnected pin report shows that the net is not connected because of the null padstack.
regards
masa
  • SaiPavanl
    0 SaiPavanl over 1 year ago
    Hello Masa, To avoid saving the Padstack with Null value, there is a variable "padstack_allow_null" in User Preferences UI>Padstack_Editor which needs to be unchecked. Regarding identifying null Padstacks, I need to check further if there's an available option and will let you know.
