  3. How to split the etch plane with same net name
  • State Verified Answer
  • Answers 1
  • Subscribers 166
  • Views 6715
RohitRohan
RohitRohan over 1 year ago
Hai Community,
I have a PCB board where the bottom layer is defined as a GND plane. I would like to split this plane into two separate sections while keeping both sections assigned to the same net name (GND).
Could anyone please suggest the best method to achieve this? I am looking for guidance on how to effectively split the plane while ensuring proper electrical performance and connectivity.
Your valuable suggestions and insights would be greatly appreciated.
Rohit Rohan
  • vidhyaparameswari
    vidhyaparameswari over 1 year ago +2 verified
    Hi Rohit, To divide a board into two halves and create a split plane with the same net name, follow these steps: **Step 1: Add a dividing line** Use the Antietch feature to add a line on the bottom…
  • avant
    avant over 1 year ago +1
    I'd create two planes. You could add a route keep-out shape (on that layer) along the break.
  • Hoangkhoipcb
    Hoangkhoipcb over 1 year ago +1
    Hi RohitRohan ! you refer the command delete by rectangle Best reguadrds, HoangKhoi
  • JCTEYSSIER0
    0 JCTEYSSIER0 over 1 year ago in reply to zpofrp
    One other way i already use with sucess: use two shapes. On one shape add property "VOID_SAME_NET".
    With it, shapes does not connect even if connected to same net. Use shape priority to set the one to be voided.
    Use a cline if you whish to connect shapes at one pint on same layer
