  3. How to split the etch plane with same net name
  • State Verified Answer
  • Answers 1
  • Subscribers 166
  • Views 6713
RohitRohan
RohitRohan over 1 year ago
Hai Community,
I have a PCB board where the bottom layer is defined as a GND plane. I would like to split this plane into two separate sections while keeping both sections assigned to the same net name (GND).
Could anyone please suggest the best method to achieve this? I am looking for guidance on how to effectively split the plane while ensuring proper electrical performance and connectivity.
Your valuable suggestions and insights would be greatly appreciated.
Rohit Rohan
  • vidhyaparameswari
    vidhyaparameswari over 1 year ago +2 verified
    Hi Rohit, To divide a board into two halves and create a split plane with the same net name, follow these steps: **Step 1: Add a dividing line** Use the Antietch feature to add a line on the bottom…
  • avant
    avant over 1 year ago +1
    I'd create two planes. You could add a route keep-out shape (on that layer) along the break.
  • Hoangkhoipcb
    Hoangkhoipcb over 1 year ago +1
    Hi RohitRohan ! you refer the command delete by rectangle Best reguadrds, HoangKhoi
  • avant
    0 avant over 1 year ago
  • Hoangkhoipcb
    0 Hoangkhoipcb over 1 year ago
    Hi RohitRohan!
    Best reguadrds,
    HoangKhoi
  • vidhyaparameswari
    +1 vidhyaparameswari over 1 year ago
    Hi Rohit,
    Use the Antietch feature to add a line on the bottom layer. You can adjust the line width to control the spacing between shapes as needed. Ensure the line divides the board into separate sections.
    **Step 2: Create a split plane**
    Go to **Edit** > **Split Plane** > **Create** to generate a shape in Etch.
    **Step 3: Assign nets to each section**
    The shape will be created, and you can then assign nets to each section individually.
    By following these steps, you can create a split plane that divides the board into two halves with the same net name.
    • Vote Up +2 Vote Down
  • RohitRohan
    0 RohitRohan over 1 year ago in reply to vidhyaparameswari
    Hai Vidhya,
    Thanks for your response, i really appreciate your efforts in providing the answer.
    I will perform the steps as suggested and will let you know how it goes ASAP.
    Rohit Rohan
  • zpofrp
    0 zpofrp over 1 year ago in reply to vidhyaparameswari
    Hi vidhyaparameswari ,
    I use this function to split a plane for every metal, but Anti-conductor needs to be adjusted constantly during the design process, so the workload is very large and I need to traverse layer by layer.
    I want to use skill to implement traversal action,but the skill is wrong, now i dont fnd this kill.
    Do you have similar skills?
