  3. Changing gap for routed diff pairs
  • State Verified Answer
  • Replies 9
  • Subscribers 167
  • Views 9087
FilipSwe
FilipSwe over 1 year ago
I have many already routed diff pairs in a design. After some interal discussion we want to lower trace width and that in turn also lowers the primary gap for the differential signals.
Changing the trace width is easy, simply select the nets and right click to change line width. Is there something similar I can do to change the gap between the differential pairs without rerouting them?
Filip
  • steve
    steve over 1 year ago +1 verified
    Look under Route - unsupported Prototypes for resize/resapce diffpair. Need at least an Allegro PCB Designer license to see this. Its a prototype feature so maybe not perfect but should help.
  • DavidJHutchins
    DavidJHutchins over 1 year ago in reply to steve +1
    the info below is from another forum posting: The Resize/Respace Diff Pairs command ignores 45-degree traces when tolerances are set to 0 . From Setup > Constraints > Physical > Differential Pair > …
  • JM20241029170
    JM20241029170 5 months ago in reply to avant +1
    This was a lifesaver. The resize->diff pair isn't listed on my Allegro X Artist.
  • zpofrp
    0 zpofrp over 1 year ago in reply to DavidJHutchins
    only change width, space dont change for all degree traces?
  • DavidJHutchins
    0 DavidJHutchins over 1 year ago in reply to zpofrp
    The only solution I know of is to delete the diff-pair routing & route it again to match the changed constraints
  • avant
    0 avant over 1 year ago in reply to DavidJHutchins
    Manually change the trace widths.
    Then perform a slide command on one of the traces, the spacing will change to match constraints.
    May have to pick a trace in several spots to have all traces at new spacing.
  • JM20241029170
    0 JM20241029170 5 months ago in reply to avant
