  3. Changing gap for routed diff pairs
  • State Verified Answer
  • Replies 9
  • Subscribers 167
  • Views 9079
FilipSwe
FilipSwe over 1 year ago
I have many already routed diff pairs in a design. After some interal discussion we want to lower trace width and that in turn also lowers the primary gap for the differential signals.
Changing the trace width is easy, simply select the nets and right click to change line width. Is there something similar I can do to change the gap between the differential pairs without rerouting them?
Filip
  • steve
    steve over 1 year ago +1 verified
    Look under Route - unsupported Prototypes for resize/resapce diffpair. Need at least an Allegro PCB Designer license to see this. Its a prototype feature so maybe not perfect but should help.
  • DavidJHutchins
    DavidJHutchins over 1 year ago in reply to steve +1
    the info below is from another forum posting: The Resize/Respace Diff Pairs command ignores 45-degree traces when tolerances are set to 0 . From Setup > Constraints > Physical > Differential Pair > …
  • JM20241029170
    JM20241029170 5 months ago in reply to avant +1
    This was a lifesaver. The resize->diff pair isn't listed on my Allegro X Artist.
  • avant
    0 avant over 1 year ago
    Use the slide cline function.
  • FilipSwe
    0 FilipSwe over 1 year ago in reply to avant
    The slide function only allows me to manually change gap for each diff pair trace. This would take a long time. Or do I misunderstand you?
    To clarify I want to change the gap on many diff pairs at the same time.
  • steve
    +1 steve over 1 year ago
  • DavidJHutchins
    0 DavidJHutchins over 1 year ago in reply to steve
    The Resize/Respace Diff Pairs command ignores 45-degree traces when tolerances are set to 0. From Setup > Constraints > Physical > Differential Pair >  (+)Tolerance, set it to an appropriate small value, but non-zero. This will apply the modified spacing to the angled traces.
  • FilipSwe
    0 FilipSwe over 1 year ago in reply to DavidJHutchins
    Thank you Steve and David. This helps a lot.
