  3. How Can I use skill make_axlPadStackPad to create a Rounded...
  • State Suggested Answer
  • Answers 1
  • Views 4195
How Can I use skill make_axlPadStackPad to create a Rounded Rectangle pad
CM202502059246
CM202502059246 over 1 year ago
;TOP PAD pad_list = cons(make_axlPadStackPad(?layer "TOP" ?type 'REGULAR ?figure figure ?figureSize (100:10)) nil ) ;SOLDERMASK_TOP PAD pad_list = cons(make_axlPadStackPad(?layer "SOLDERMASK_TOP" ?type 'REGULAR ?figure figure ?figureSize (104):(14)) pad_list ) ;PASTEMASK_TOP PAD pad_list = cons(make_axlPadStackPad(?layer "PASTEMASK_TOP" ?type 'REGULAR ?figure figure ?figureSize (100:10)) pad_list ) axlDBCreatePadStack("TEST_PAD" nil pad_list t)
I know ?figure figure  setup ->
Circle is 'CIRCLE
Oblong is 'OBLONG_X
Rectangle is 'RECTANGLE
But I don't know how to make Rounded Rectangle and how can I use it
  • CM202502059246
    0 CM202502059246 over 1 year ago
    ok I found the answer
    Rounded Rectangle is 'ROUNDED_RECTANGLE
    ttW = 100
    ttH = 20
    corners = "UR-LR"
    figure = 'ROUNDED_RECTANGLE
    ;TOP Pad
    ?layer "TOP"
    ?type 'REGULAR
    ?figure figure
    ?figureSize (ttW:ttH)
    ?corners corners
    ?radius ttH/2 )
    nil
