  3. Net-tie without manually specifying net names
  • State Verified Answer
  • Replies 8
  • Subscribers 167
  • Views 10818
pertinax
pertinax over 1 year ago
I want to create a net-tie in the schematic and layout. I.e., a schematic symbol with two pins and a corresponding footprint with two shorted pins.  See the screenshots below.
I have read this document https://www.parallel-systems.co.uk/wp-content/uploads/2020/02/Netshort_Definition.pdf and also this RAK https://support.cadence.com/apex/ArticleAttachmentPortal?id=a1O0V000007MqM1UAK&pageName=ArticleContent.
Without adding any properties, the shorted footprint causes DRC errors in the layout. In my case I get "SMD Pin to Pin Spacing" DRC. It is possible to add a NET_SHORT property, either to the schematic component as described in the first document or in the layout using the "net short" command. However, this requires either specifying the exact net names in the schematic property or manually performing the net short in the layout.
In the second document above, I read about the PIN_SHORT property. Apparently it can be added to the schematic symbol, giving the names of the pins, and the "packager" will automatically create the NET_SHORT property during packaging. I added the property PIN_SHORT=1:2 to the schematic symbol, with pin names for the pins set to "1" and "2". This did not work.
I read that the packager needs the option "PROCESS_PIN_SHORT_PROP 'ON'" for this to work (page 12 of the RAK). However, I don't know if this is applicable to Orcad X Professional (PCB Editor 23.1), or where to add this said option. According to the document, it needs to be added to the "project cpm file" or "site cpm file".
Thanks for any help!
  • excellon1
    excellon1 over 1 year ago +1 verified
    Hi there. There is another way to do this. In the schematic you cab use any 2 pin symbol you like. In the PCB Symbol Editor create a 2 pin symbol where by both pins are shorted together so as to form a…
  • excellon1
    excellon1 over 1 year ago in reply to pertinax +1 verified
    Hi, In the symbol editor adding properties works differently, try the following. On the tool bar click on Edit menu and choose "Properties" Next go to the find filter. On the find filter panel there…
  • pertinax
    0 pertinax over 1 year ago in reply to AC202502108327
    Hello, I cannot make this work. I have found one CPM-file in C:\Cadence\SPB_23.1\share\cdssetup\projmgr and it has this option enabled.
    Is the packager and cpm-files used with PCB Editor? When googling and reading configuration options it seems the CPM-files are used by another tool called projmgr or Project Manager. Tried to run this tool and successfully created a project, but when trying to launch design entry it tried to start "Concept HDL" and failed with a license error. Perhaps the PIN_SHORT method is not supported by OrCAD Capture?
  • pertinax
    0 pertinax over 1 year ago in reply to excellon1
    Hi again,
    Thanks for your detailed instructions. Apart from solving my problem, the trick how to add properties to the symbol was a real gold nugget. Not really apparent how to do this otherwise.
    I tried a couple of times and finally I got the properties editor window to appear following your instructions. With the added Nodrc_Sym_Same_Pin property I now have a working solution. I can add my nettie part in the schematic and it will create a nettie in the layout without any DRC errors.
    Right now, I will use the nettie to create a sense connection for a current shunt. For this, I created a footprint with two overlapping rectangular pads, having the same width as the sense trace itself. I found that the pads need to be spaced far enough apart in order not to get clearance errors when adding clines, this could be done by offsetting the pad connection point in the padstack editor.
    Best regards,
  • excellon1
    0 excellon1 over 1 year ago in reply to pertinax
    Hi, On that gold nugget for accessing the symbol editor properties, as with all things Allegro there is another way to do that too :)
    A hot key is a good solution in this regard. Here is a hot key that you can add to your .env file.
    funckey H "prepopup; property edit; setwindow form.find; FORM find name_type Drawing"
    The hotkey uses the H key. You could modify it to any key you wish to use.
    All the best.
