  3. swapping net names
  • State Verified Answer
  • Subscribers 166
  • Views 5558
swapping net names
masamasa
masamasa over 1 year ago
hello
is there an easy way to swap the net names?
i finished my design but i found out some nets needed to be swapped.
for instance, my design has net_a and net_b.
i change net_a to net_ax so that i can change net_b to net_a on net logic.
then i change net_ax to net_b on net logic.
i know how to swap nets but i have about 200 nets needed to be swapped.
so i would like to find some easy way to swap nets.
regards
masa
  • avant
    avant over 1 year ago +2
    I assume you don't have a schematic you can edit. Put the board into a folder and export all libraries. File / export netlist / with properties. Edit and save this netlist. Import the edited netlist…
  • DavidJHutchins
    DavidJHutchins over 1 year ago in reply to avant +2 verified
    To interactively swap net names I wrote the following skill code: <<< procedure((Swap_Net_Names) prog((NetA NameA NetB NameB TmpName num) (axlSetFindFilter ?enabled list("noall" "nets" ) ?onButtons…
  • avant
    0 avant over 1 year ago
    Import the edited netlist into the board. Select "other" to import a flat netlist.
    • Vote Up +2 Vote Down
  • DavidJHutchins
    +1 DavidJHutchins over 1 year ago in reply to avant
    (axlSetFindFilter ?enabled list("noall" "nets" ) ?onButtons list("noall" "nets" ))
    (axlClearSelSet)
    (axlMsgPut "Select 1st net to swap:")
    (NetA = car((axlGetSelSet (axlSingleSelectPoint))))
    when(NetA
    ;axlPrintDbid(NetA)
    (NameA = NetA->name)
    (axlClearSelSet)
    (axlMsgPut "Select 2nd net to swap:")
    (NetB = car((axlGetSelSet (axlSingleSelectPoint))))
    while( NetA == NetB
    axlMsgPut("Same Net: ReSelect 2nd net to swap:")
    ;axlPrintDbid(NetB)
    (axlClearSelSet)
    (num = 0)
    (NameB = NetB->name)
    axlMsgPut("Swapping Net names %s and %s" NameA NameB)
    sprintf(TmpName "%s%d" NetB->name num)
    while(axlSingleSelectName("NET" '(TmpName) )
    (num++)
    axlMsgPut("Temp Net name %s" TmpName)
    axlRenameNet(NameA TmpName)
    axlRenameNet(NameB NameA)
    axlRenameNet(TmpName NameB)
    axlVisibleUpdate(t)
    ;return()
    ;exit()
    axlCmdRegister( "Swap_Net_Names" 'Swap_Net_Names ?cmdType "general")
    Below is the journal file entries when running it:
    \i (00:00:26) swap_net_names
    \t (00:00:26) Select 1st net to swap:
    \i (00:00:29) pick 1486.13 2108.29
    \t (00:00:29) last pick: 1486.13 2108.29
    \t (00:00:29) Select 2nd net to swap:
    \i (00:00:33) pick 1289.76 2102.00
    \t (00:00:33) last pick: 1289.76 2102.00
    \t (00:00:33) Swapping Net names DVDD_SW and VDD_0P75V
    \t (00:00:33) Temp Net name VDD_0P75V0
    \i (00:00:33) generaledit
  • masamasa
    0 masamasa over 1 year ago in reply to DavidJHutchins
    thank u, david.
    it works perfectly.
    amazing!
    regards
    masa
  • KD202502275710
    0 KD202502275710 over 1 year ago in reply to avant
    Worked for me
  • masamasa
    0 masamasa over 1 year ago in reply to avant
    hello avant:
    thank u for ur response.
    unfortunately my design is very big and importing and exporting the netlist takes one or two days.
    i need something easy.
    i was looking for something like the skill that david made.
    regards
    masa
