  3. waived errors
  • State Verified Answer
  • Views 4917
waived errors
masamasa
masamasa over 1 year ago
hello
i have a design that someone made.
this design has many waived errors but they do not show up on the design.
is there a way to show all waived errors on a design?
i know that i can get a list of waived errors but i would like to see the waived errors on that design.
i sometimes waive errors but they still show up on my design.
regards
masa
  • excellon1
    excellon1 over 1 year ago in reply to excellon1 +1 verified
    Hi Masa Forgot to mention, Go to Display on the tool bar. Under "Waive DRC" there are options. Check if they work. "Restore. restore All" Best regards.
  • DavidJHutchins
    0 DavidJHutchins over 1 year ago
    The following command will clear the 'waived' status and make the DRC's visiable:
    skill axlDRCWaive(nil axlDBGetDesign()->waived)
  • excellon1
    0 excellon1 over 1 year ago
    Hi Masa,
    Check that the waived DRC color is of a color that will show. Display > Color/Visibility > Display Panel.
    On the visibility pane, check to see if the DRC is checked  to show.
    Best Regards.
  • excellon1
    +1 excellon1 over 1 year ago in reply to excellon1
    Hi Masa
    Best regards.
  • masamasa
    0 masamasa over 1 year ago in reply to DavidJHutchins
    thank u for ur response, david
    this command is changing waved drc errors to drc errors.
    but i would like to make wavied erros visible with keep them as wavied erros as is.
    regards
    masa
  • masamasa
    0 masamasa over 1 year ago in reply to excellon1
    thank u for ur response.
    yes, this is what i was looking for.
    regards
    masa
