  3. importing\exporting constraints
  • State Suggested Answer
  • Answers 1
  • Views 1162
masamasa
masamasa over 1 year ago
hello
is there a way to import/export the physical and spacing constraints on particular layers only?
i have merged 2 designs with 2 different constraints.
i would like to import/export constraints partially.
regards
masa
  • mahimag
    mahimag over 1 year ago +1 suggested
    Hello masamasa , currently you cannot export layer wise. But if you export a worksheet, you can edit it to remove the extras. Although this comes with caution, as there are fields which needs to be there…
  • mahimag
    0 mahimag over 1 year ago
    Hello masamasa , currently you cannot export layer wise. But if you export a worksheet, you can edit it to remove the extras. Although this comes with caution, as there are fields which needs to be there while import.
