  3. Generating Port in PowerSI: Error "Failed to generate ports...
  • State Suggested Answer
  • Answers 1
  • Views 2099
Generating Port in PowerSI: Error "Failed to generate ports for circuit: No Negative Terminal"
NN202502257432
NN202502257432 over 1 year ago
Hi All,
I am trying to generate a S-parameter File of a PCB Transmission line for a C-PHY channel. The PCB is easy (as shown below). The port are 7 A_in, B_in & C_in and A_out, B_out &C_out + GND
The final goal is to use it in Virtuoso to simulate a High Speed TL using the nport cell from AnalogLib
My Question: I am trying to generate the 7 ports, but I was uncapable. I was following the videos from Prof. Om Mandhana and the user guide. I am able to create the PCB with KiCad and export it to PowerSI... but no solution.
Any hint, link to a resource or idea on how to proceed?
Thanks a lot!! :)
Albert
  • Sumith
    Sumith over 1 year ago +1 suggested
    You can try Pin-Based port generation method in PowerSI. This is a good reference Article (20509258) Title: Case Study of 2N and N+1 S-Parameter Generation URL: https://support.cadence.com/apex/ArticleAttachmentPortal…
  • Sumith
    0 Sumith over 1 year ago
    You can try Pin-Based port generation method in PowerSI. This is a good reference Article (20509258) Title: Case Study of 2N and N+1 S-Parameter Generation URL: https://support.cadence.com/apex/ArticleAttachmentPortal?id=a1O3w000009lsL1EAI
    Best Regards,
    Sumith
