  3. Allegro SKILL Code Library 2025 ("content retired" - where...
  • State Verified Answer
  • Views 2936
Allegro SKILL Code Library 2025 ("content retired" - where to find?)
RT202503126350
RT202503126350 over 1 year ago
It seems that the link to the PCB Editor SKILL Code Library is dead.
At the support home for Skill scripts:
https://support.cadence.com/apex/Coveo_CommunitySearch#t=SkillInformation&language=en&pageName=Scripts
the top pinned link is to "Allegro PCB Editor SKILL Code Library", but the link is dead or "retired", as described when I click on the link (The content you are trying to access has been retired and is no longer available.):
https://support.cadence.com/apex/ArticleAttachmentPortal?id=a1Od000000051TEEAY&pageName=ArticleContent
Does anyone have an alternate link, or can someone at Cadence look into why this content was retired, and whether there is a good alternative.  If the content was removed intentionally, you should probably remove this pinned link, to keep poor engineers from getting their hopes up.
  • techiecs
    techiecs over 1 year ago in reply to techiecs +1 verified
    RT202503126350 I checked ' Allegro PCB Editor SKILL Code Library' page today and it seems to be working now. The page is now working fine and accessible. You can check that for yourself as well.
  • techiecs
    0 techiecs over 1 year ago
    Allegro PCB Editor SKILL Code Library page is not getting fetched in Cadence ASK portal. This is a known issue and IT from Cadence is looking into this issue and the page will be up running soon.
    Meanwhile if you want to access any SKILL code, then you can refer to SKILL artifacts provided on Cadence ASK portal(https://ask.cadence.com) as per your requirement by searching with relevant keywords.
    Allegro PCB Editor SKILL Code Library and other live pages will soon be accessible once this issue is fixed.
  • techiecs
    +1 techiecs over 1 year ago in reply to techiecs
    RT202503126350 I checked 'Allegro PCB Editor SKILL Code Library' page today and it seems to be working now. The page is now working fine and accessible. You can check that for yourself as well.
  • RT202503126350
    0 RT202503126350 over 1 year ago in reply to techiecs
    Thanks for the update.  Working for me too.  Much appreciated.
