  3. height zone check
  • State Suggested Answer
  • Answers 1
  • Views 3561
height zone check
VishnuVRD
VishnuVRD over 1 year ago
I've few areas from importing EMN file where there is "PACKAGE_HEIGHT_MIN" property attached to them. I've Package Height property attached to symbols as well. Is there any way to check DRC between those two properties? .If I place any component in area of "PACKAGE_HEIGHT_MIN" = 0, I need DRC error,
Thank you
  • steve
    0 steve over 1 year ago
    Yes - Make sure the areas are Package_Keepout / Top or Bottom and assign the height property to them. For symbols again make sure that the Place_Bound_Top shape has the height property then you should see DRC errors. There is an app note with a bit more detail Height Definition in PCB Editor
