  3. How to assigning Color to a subject [Allegro free physical...
  • State Verified Answer
  • Answers 1
  • Views 4408
How to assigning Color to a subject [Allegro free physical viewer 24.1]
KS20250407368
KS20250407368 over 1 year ago
Hi all,
Does anyone know How to assigning Color to a subject ? Not nets, I knew nets can be assigned a color.
I am using [Allegro free physical viewer 24.1]
Thank you very much.
  • vidhyaparameswari
    +1 vidhyaparameswari over 1 year ago
    Hi KS20250407368,
    To do so, simply use the "assign color" command in the command window, but first ensure that the object you want to color is enabled in the Selection Filter tab.
    Alternatively, you can also adjust the color settings by going to Visibility > Display > General > Temp Highlight.
    Please check and let me know if it helps!!
  • KS20250407368
    0 KS20250407368 over 1 year ago in reply to vidhyaparameswari
    It works.  Thank you very much.
