  3. Test Your Know How: PCB Separation
  • Replies 16
  • Views 15170
PCBTech
PCBTech over 1 year ago
Organize these three separation technologies into order:
1. SPEED
2. COST
3. STRESS
A = Scoring, B = Tab Routing/Milling, C = Lazer Cutting
Which is the fastest speed, the highest cost, and the highest stress on the PCB and surrounding components?
If you are concerned about product lifespan in your designs, do you consider these factors? Simply answer your order in the comments below. Any further input or questions from your experiences are also very welcome!
  • avant
    avant over 1 year ago +2
    We typically use v-groove and a "pizza" cutter to separate. This requires components to be spaced away from the edge, we have seen components damaged if too close. For our high volume designs, (100K…
  • DE202408202727
    DE202408202727 over 1 year ago in reply to John T +2
    We use all these methods. They all have their own advantages and disadvantages. Most often we use Mouse bites and v-scores on the same design. Laser singulation is great for rigid-flex or very small…
  • excellon1
    excellon1 over 1 year ago in reply to DE202408202727 +2
    Hi Dave. The boards we do are plain vanilla for the most part with rounded edges on the corners, needless to say they can be of various sizes. Our preference is to ship the boards to the Assy House. On…
  • DE202408202727
    DE202408202727 over 1 year ago in reply to excellon1
    Hi Excellon,
    You have piqued my interest. I have been involved in many hundreds of board designs and it is very rare to be able to design one without an array (as I prefer to call it). I have visited numerous fabricators and, again, it is very rare to see boards that don't need to be singulated on their production lines.
    The cost of the extra step to singulate a board, and the cost of the extra laminate, adds up. Not having to singulate would be a big cost saving.
    I spoke to my production engineers about your experience and they are sceptical. Can you please elaborate a little more on how you achieve this nirvana? It would be  a great conference presentation.
    Cheers,
    Dave
  • excellon1
    Hi Dave.
    The boards we do are plain vanilla for the most part with rounded edges on the corners, needless to say they can be of various sizes. Our preference is to ship the boards to the Assy House. On the boards they do incorporate space between the parallel
    edges of the board and components. The minimum space we use is typically 150mil from the board edge, sometimes this can be 200mil if the board is double sided. Basic idea is to have the breakaway rail incorporated into the board so the SMD placer can handle it. Or put another way have margin on the board design so no breakaway rails are needed.
    If we are unable to design a board to meet the minimums, then a fixture would be needed to hold the boards This fixture then gets slid into the SMD placer. Typically there is a cost adder if a fixture is needed. Some machines today work on the principle of work holding in that the variable is the board size "Width" Provided the board can be held in place and presented to the SMD placer then the width of the board is a non issue. If I am not mistaken Panasonic equipment has such a feature. The work holder is the conveyor.
    If we have to use breakaway rails and we have in the past, typically these are 400 mil in width. They also contain tooling holes and fiducials.
    You make a very good point on the savings with respect to extra laminate. If this can be minimized then there will be a cost saving.
    I think there is not a one size fits all here, Its going to be down to the assembly house and the equipment they have. Certainly it is good to ask questions in advance of a build to see if any savings are possible or possibly a new approach in how the boards are designed could get you there too. One can never ask enough questions on this stuff as the equipment today is light years ahead of where it was 10 Years ago.
    One last thing on this. It is possible to design a board that does not have any real margin around its edges. On the board 2 or 4 holes are included for mounting purposes. The Board goes into the SMD placer and stops. Then swage pins come up to hold the board. The placer then moves the conveyor rail away from the board and the Placement begins. These type of placers can handle some very esoteric shaped boards such as round, or odd shaped etc. Memory is a bit foggy on this, it might be a universal machine.
    Best regards.
    • Vote Up +2 Vote Down
  • excellon1
    excellon1 over 1 year ago in reply to excellon1
    Hi Dave,
    Just a quick follow up. I found a video on how small computer motherboards are manufactured that might be of interest. Jump on youtube and do a search for  Inside China's Mini PC Production: How Tiny Computers Are Made
    Go to about 8.10 in the video. At that point it evolves where by the board is mounted in a carrier and then put into the SMD Placer.
    The video clearly shows that the board is de-paneled. The carrier method means no breakaway rails etc are needed on the board.
    Perhaps that might be something to help reduce cost and increase reliability since the stress on the board is out of the equation.
    Best Regards.
  • DE202408202727
    That's a fascinating video for a number of reasons.
    We use pallets for very thin boards and flexes but still use arrays for those.
    Food for thought.
    Cheers,
    Dave
  • John T
    John T over 1 year ago in reply to DE202408202727
    Hi Excellon1 & Dave, great discussion!
    I am back from holidays and just wanted to add in some thoughts on this. Agree that we need to keep asking these questions, discuss and learn from everyone - especially with both our assemblers and fabricators!  Also, vanilla is a very underrated flavour; but I guess we are debating here if we need to pay for extra sprinkles or not!
    I really enjoyed the video thanks Excellon1! The wave soldering conveyor belt was very interesting to see; I noted it had custom pre-cut openings for that product to match the connector positions. That was a nice touch I hadn't seen before!
    On the negative side, I see an exceptional amount of manual intervention required for the assembly flow. I am more used to an automated processes that minimises physical hands. One major strategy to achieve this is to minimise or eliminate the amount of wave soldering on the board. Ideally smt side 1 and side 2 only is best, fastest and therefore cheapest. Eliminating those pallets is actually a cost improvement; which take extra time, manual intervention and cost to load then unload; not to mention the bespoke design and material cost of those things...
     I have more thoughts if you are interested to discuss further! Would love to hear anyone else's experiences also!
