  3. Test Your Know How: PCB Separation
  • Replies 16
  • Views 15176
PCBTech
PCBTech over 1 year ago
Organize these three separation technologies into order:
1. SPEED
2. COST
3. STRESS
A = Scoring, B = Tab Routing/Milling, C = Lazer Cutting
Which is the fastest speed, the highest cost, and the highest stress on the PCB and surrounding components?
If you are concerned about product lifespan in your designs, do you consider these factors? Simply answer your order in the comments below. Any further input or questions from your experiences are also very welcome!
  • avant
    avant over 1 year ago +2
    We typically use v-groove and a "pizza" cutter to separate. This requires components to be spaced away from the edge, we have seen components damaged if too close. For our high volume designs, (100K…
  • DE202408202727
    DE202408202727 over 1 year ago in reply to John T +2
    We use all these methods. They all have their own advantages and disadvantages. Most often we use Mouse bites and v-scores on the same design. Laser singulation is great for rigid-flex or very small…
  • excellon1
    excellon1 over 1 year ago in reply to DE202408202727 +2
    Hi Dave. The boards we do are plain vanilla for the most part with rounded edges on the corners, needless to say they can be of various sizes. Our preference is to ship the boards to the Assy House. On…
  • excellon1
    excellon1 over 1 year ago in reply to John T
    Hi John,
    Yes indeed, would love to hear any additional thoughts you might have. On the assembly flow, I think they hit the balance very well, based on the equipment they have. The one thing I liked was the high degree of protecting the board by using a pallet as a carrier.
    This IMHO bodes well for the quality of the finished product. The huge advantage of the pallet is the board is ready to go. If the boards are de-paneled to begin with there is inherent quality built in. Needless to say this depends alot on the capability and agility of the SMD
    placement equipment.
    Good topics John !
    Best Regards.
  • John T
    John T over 1 year ago in reply to excellon1
    Hi Excellon1, I see you got nominated for "Meet the Champion of the Month: August 2025". Congratulations and well deserved!
    After seeing this, I remembered this conversation. In follow up, I am definitely in favor of penalization. I cringe when I see operations happening on single PCBs. A major part of production time loss is the load unload cycles That's one major reason why penalization saves time and money. Why operate on one component when a pallet of 6, 8 or 10 can be operated upon before passing the job on to the next stage. Placement machines on the market can handle much larger pcb sizes than this example. (Example specs of 610 x 508mm are available) I would also argue that something is wrong when a guy is full time employed to sit there and touch up solder joints. Would you agree?
  • DE202408202727
    I too pass on my congratulations to Excellon1. Well deserved Paul!
    I would be wary of panels longer than about 300mm these days. IPC allows for board "stretch" of up to 0.2mm and fabricators are reluctant to specify less. This isn't a problem for SMD placement machines, but can cause problems for stencil printing when using 0201s and similar, or smaller devices. I have seen a board come in with a 0.2mm "stretch" and it caused considerable problems in assembly. I'd prefer to keep panels shorter that 200mm. Of course, if your assembly house has access to jet printing capability, this is less of a problem for low volume runs.
  • John T
    John T over 1 year ago in reply to DE202408202727
    True eDave, thanks for weighing in with good points. True that the larger panels suffer from stretch issues. For such large placement areas, it makes sense to run multiple panels at once to utilize the machine to its maximum capability. Even still we would endeavor to maximize individual panel size up to 350mm length and beyond. Some layout techniques are possible to minimize the effects of stretch. I would be interested to hear more about the jet printing. Have you used that?
  • DE202408202727
    I haven't used jet printing. However I'm familiar with the benefits and disadvantages.
    Pros:
    • No stencils
    • Reliable and predictable paste deposits
    • Easy to test different paste patterns
    Cons:
    • Slow printing compared with stencils
    • Expensive paste
    • Good jet printers are expensive
