  3. detele by rectangle
  • State Verified Answer
  • Replies 10
  • Views 6230
detele by rectangle
masamasa
masamasa over 1 year ago
hello
i do know that we can delete some area on clines by the "delete by rectangle" command.
but is there a way to select the cline area by poligon to delete so that the area is not a rectangle but a parallelogram as show below?
regards
masa
  • excellon1
    excellon1 over 1 year ago in reply to masamasa +2 verified
    Hi Masa, The Scalpel routine works like drawing a thick or thin line through the traces. Basically similar to a blade cutting something. If you run the command scalpel followed by a number, the number…
  • andakConsultingLtd
    0 andakConsultingLtd over 1 year ago in reply to masamasa
    you should be able to write a SKILL around SCALPEL that does the job. SCALPEL cuts the traces at intersect while the vertexes against the closed loop will give you the information of the clines located inside the loop.
  • masamasa
    0 masamasa over 1 year ago in reply to andakConsultingLtd
    thank u for ur  response.
    unfortunately as i wrote above, the scalpel code does not work.
    this skill code deletes clines located outside of the selected area and does not delete some clines located inside of the selected area.
    and unfortuantely i do not know how to write a skill code.
    regards
    masa
  • excellon1
    +1 excellon1 over 1 year ago in reply to masamasa
    Hi Masa,
    If you run the command scalpel followed by a number, the number will be the width of the cut.
    For a 100 mil cut  try scalpel 100
    This will delete the trace segments by 100 mils wherever your cut line was placed. I don't know of any routine that works like drawing a polyagon.
    There is also another method that is faster for cutting clines, You could take your board into "Specctra" and use the cut and delete segment options to basically create any cut type you want really fast. In specctra you draw the first cut line then the next cut line which cuts the traces. You then delete the traces between the cuts.
    Best regards.
    • Vote Up +2 Vote Down
  • masamasa
    0 masamasa over 1 year ago in reply to excellon1
    thank u for ur explanation, excellon1.
    i can use this scalpel code with an offset value.
    although i would like to use scalpel 0 and the zero offset value gives me an error, i can work around.
    regards
    masa
  • excellon1
    0 excellon1 over 1 year ago in reply to masamasa
    Sure thing Masa, glad to help you out.
    The thing on having an offset of 0 is that when the clines got cut I reckon one would not see any cut. BTW the default value is 12mil as far as I can recall.
    All the best.
