  3. updated Scalpel skill file
  • Replies 8
  • Views 5580
DavidJHutchins
DavidJHutchins over 1 year ago
attached is an updated version of the 'scalpel' custom skill code with 2 changes:
Updated to correctly handle non-orthogonal/diagonal routing ( i.e. fiber-weave zig-zag routing )
Added 'undo' capability
https://community.cadence.com/cfs-file/__key/communityserver-discussions-components-files/28/scalpel.zip
  • DavidJHutchins
    DavidJHutchins over 1 year ago in reply to DavidJHutchins +1
    Well crap, I had a typo in the original file I uploaded: D:\SPB_Data\>diff scalpel.il~ scalpel.il 74c74 < axlCmdRegister( "scapel" 'scalpel ?cmdType "interactive" ?undo t) --- > axlCmdRegister( "scalpel…
  • masamasa
    masamasa over 1 year ago in reply to DavidJHutchins
    thank u, david as always.
    i get this error.
    Command> scalpel 20 t
    *Error* scalpel: too many arguments (at most 1 expected, 2 given) - ("20" "t")
    regards
    masa
  • masamasa
    masamasa over 1 year ago in reply to masamasa
    thank u david,
    the latest skill code works fine.
    regards
    masa
  • DavidJHutchins
    DavidJHutchins over 1 year ago in reply to masamasa
    the attached zip file contains the new 2.6 version which allows the deletion of the segments within the cut-line boundary,
    below is the additional help text:
    	where 't' enables the inner-area Delete capability
          the segments within the closed cut-line boundary are deleted
              unless the cut-line boundary crosses itself - the tool doesn't like crossed boundaries :(
    https://community.cadence.com/cfs-file/__key/communityserver-discussions-components-files/28/scalpel_5F00_2p6.zip
