  3. importing a sub-drawing
  • State Verified Answer
  • Views 5436
masamasa
masamasa over 1 year ago
hello
is there a way to import a sub-drawing and placing it in mirror?
i do not see any menu items for mirroring imported sub drawings.
regards
masa
  • JuanCR
    JuanCR over 1 year ago +1
    Hi! So you want to place it as mirrored at once? Have you tried placing it on a new board, mirroring it, then saving the sub-drawing ?
  • DavidJHutchins
    DavidJHutchins over 1 year ago in reply to masamasa +1
    Since Allegro/APD do not allow mirroring the data during import, I tried mirroring the data in the clp file, below is a simple 'sed' editting script: s/(_clpAdjustPt /(_clpAdjustPt -/g s/_clpAdjustPt…
  • DavidJHutchins
    DavidJHutchins over 1 year ago in reply to DavidJHutchins +1 verified
    I wrote the custom command 'mir_clp' in the attached zip file to preform the editing from within the Allegro/APD tool below is the journal file entries: \i (00:00:23) skill 'load "mir_clp.il"' (00…
  • JuanCR
    0 JuanCR over 1 year ago
  • masamasa
    0 masamasa over 1 year ago in reply to JuanCR
    hello
    thank u for ur response.
    that is what i am doing.
    but i would like to find a way to do it in one step instead of two steps to save my time.
    what i  do not understand is that there is a rotate function but no mirror function to import a sub-drawing.
    regards
    masa
  • DavidJHutchins
    0 DavidJHutchins over 1 year ago in reply to masamasa
    s/_clpAdjustPt(/(_clpAdjustPt -/g
    s/(_clpAdjustPt --/(_clpAdjustPt /g
    s/(_clpAdjustPt -'/(_clpAdjustPt '/g
    w mirrored.clp
    it took < 1 second to run it
    C:\Temp>dir *clp
    Volume in drive C has no label.
    Volume Serial Number is 46E1-12D0
    Directory of C:\Temp
    06/11/2025 08:56 AM 1,080,758 standard.clp
    1 File(s) 1,080,758 bytes
    0 Dir(s) 64,173,797,376 bytes free
    C:\Temp>sed -nf clp_mir.sed standard.clp
    C:\Temp>dir *clp
    06/11/2025 10:06 AM 1,087,797 mirrored.clp
    2 File(s) 2,168,555 bytes
    0 Dir(s) 64,172,707,840 bytes free
    C:\Temp>
    the mirrored clp file loaded in < 2 minutes
    There are a few arc issues due to database accuracy in the original clip file:
    (_clpAdjustPt 1649.606591792885:1668.271655271171 _clp_cinfo))
  • DavidJHutchins
    +1 DavidJHutchins over 1 year ago in reply to DavidJHutchins
       (00:00:23) t
    \i (00:00:28) mir_clp
    \i (00:00:33) fillin "standard.clp"
    \t (00:00:33) 29806 lines processed in 0 seconds
    \t (00:00:33) load mirrored_standard.clp for mirrored data
    \i (00:00:33) generaledit
    \i (00:00:40) clppaste
    \i (00:00:43) fillin "mirrored_standard"
       (00:00:43) Loading cmds.cxt
    \i (00:00:48) pick -3000 0
    \t (00:00:48) last pick:  -3000.00 0.00
       (00:00:48)  10 percent completed
       (00:00:48)  20 percent completed
       (00:00:48)  30 percent completed
       (00:00:48)  40 percent completed
       (00:00:48)  50 percent completed
       (00:00:48)  60 percent completed
       (00:00:48)  70 percent completed
       (00:00:48)  80 percent completed
       (00:00:48)  90 percent completed
       (00:02:14)  100 percent completed
    \i (00:02:14) generaledit
    https://community.cadence.com/cfs-file/__key/communityserver-discussions-components-files/28/mir_5F00_clp.zip
  • masamasa
    0 masamasa over 1 year ago in reply to DavidJHutchins
    thank u, david:
    it works now
    regards
    masa
