  3. DB Doctor error, thanks
  • Subscribers 160
  • Views 2856
OE202506016519
OE202506016519 6 months ago
Hi, I was trying to open a .brd file sent by my colleague with Allegro (version 24.1), and then it  reported an error that this file was saved as version 16.6 last time, and needed to be updated with db doctor, so I opened db doctor. The "Input design with extention" was 'D:/Program Files/165k3g_81100257_Falcon_ProbeBoard_V02_20240416b.brd', and "output design" was 'C:/Users/86199/Desktop/165k3g_81100257_Falcon_ProbeBoard_V03_20240416b.brd' . But when I click on "check", it reported error and the information of error log was
Performing UPREV on the database - D:/Program Files/165k3g_81100257_Falcon_ProbeBoard_V02_20240416b.brd
Performing dbdoctor16 to bring DB up to REV16
------------------------------ Terminal Output ---------------------------------
ERROR: Uprev of revision to REV16 found errors.
Performing dbdoctor17 to bring DB up to REV17
ERROR: Uprev of revision to REV17 found errors.
ERROR: Uprev of design failed.
Looking forward to your soution. Thanks a lot !
Oswald Edmond
  • JuanCR
    0 JuanCR 6 months ago
    Hey Oswald. Can you share the contents of dbdoctor.log? We've done some tests at our end and it seems like dbdoctor 24.1 should be able to handle the uprev directly from 16.6. Maybe this is database-specific and there is some kind of corruption?
  • OE202506016519
    0 OE202506016519 5 months ago in reply to JuanCR
    sorry, there's an error that I can't upload the image, but I can copy the  text,
    here:
    <<< Design Uprev Warnings >>>
    Wed Jun 11 13:03:36 2025 Page 1
    ERROR(SPMHDB-181): The current version of software is unable to open design #T~
    aaaaab03480.tmp.
    The design was last saved using version 16.6 and must be upda~
    ted using DB Doctor. [help]
    Wed Jun 11 13:04:04 2025 Page 1
    aaaaab28732.tmp.
    thank you very much !
  • KD202502275710
    0 KD202502275710 5 months ago in reply to OE202506016519
    Can u pls try uploading the image using a different browser.. sometime that helps.
  • OE202506016519
    0 OE202506016519 5 months ago in reply to KD202502275710
    I tried, it doesn't work though. But actually the effect of text is the same as that of images.
