  3. addling lines
  • State Verified Answer
  • Replies 7
  • Subscribers 167
  • Views 5206
addling lines
masamasa
masamasa over 1 year ago
hello:
the add line command has only 3 options of off, 45, and 90 with no route offset.
is there a way to add a route offset like the add connect command on clines so that i can add 60-degree angled lines?
i am talking about not clines but lines, btw
regards
masa
  • steve
    steve over 1 year ago in reply to masamasa +1 verified
    Oops my bad, OK try invoke the Add Line command pick a start point then click on the P icon on the bottom of the canvas. Change the option to Distance + Angle and relative from last pick then type 10 30…
  • steve
    +1 steve over 1 year ago in reply to masamasa
    Oops my bad, OK try invoke the Add Line command pick a start point then click on the P icon on the bottom of the canvas. Change the option to Distance + Angle and relative from last pick then type 10 30 (distance and angle) then click on the Pick button. That should give you what you need.
  • masamasa
    0 masamasa over 1 year ago in reply to steve
    thank u, steve.
    this works now.
    this method works for the add connect command as well.
    regards
    masa
