  3. addling lines
  • State Verified Answer
  • Replies 7
  • Subscribers 167
  • Views 5199
addling lines
masamasa
masamasa over 1 year ago
hello:
the add line command has only 3 options of off, 45, and 90 with no route offset.
is there a way to add a route offset like the add connect command on clines so that i can add 60-degree angled lines?
i am talking about not clines but lines, btw
regards
masa
  • steve
    steve over 1 year ago in reply to masamasa +1 verified
    Oops my bad, OK try invoke the Add Line command pick a start point then click on the P icon on the bottom of the canvas. Change the option to Distance + Angle and relative from last pick then type 10 30…
  • Xiaome8
    0 Xiaome8 over 1 year ago
    hi masamasa ,
    here are some ideas:
    option 1 , use cline mode to add line, then convert cline to line (cline mode can use offset 60-degree) ---prerfer;
    option2 , add line, then use spin command to rotate the line to 60-degree
  • DavidJHutchins
    0 DavidJHutchins over 1 year ago in reply to Xiaome8
    Hi masamasa,
    Take a look at the forum posting from last year titled :
    ROUTE TRACES AT 22.5 DEGREES
  • masamasa
    0 masamasa over 1 year ago in reply to DavidJHutchins
    thank u for ur response, david:
    i am not talking about clines but lines, though.
    i am refering to the add line command, not the add connect command.
    regards
    masa
  • steve
    0 steve over 1 year ago in reply to masamasa
    You can try invoking the Add Line command, set the Line Lock Options to off, pick your starting point then type ix 100 < 60 (which would be a line 100 long at an angle of 60 from the start point). Obviously set the required distance and angles you need.
  • masamasa
    0 masamasa over 1 year ago in reply to steve
    thank u, steve, for ur response.
    if i type ix 100 < 60 after picking the starting point, it gives me this
    if i type ix 10 < 60 after picking the starting point, it gives me this
    it does not give me an angle but the xy delta.
    regards
    masa
