  3. How to Assign a Hotkey for "Temp Group" in Allegro Using...
  • State Suggested Answer
  • Answers 3
  • Views 1825
How to Assign a Hotkey for "Temp Group" in Allegro Using ENV File?
VK202506218248
VK202506218248 over 1 year ago
Hi everyone,
I'm trying to assign a hotkey to activate the Temp Group option in Allegro (version 23.1), using the ENV file. I wrote the following line:
funckey t "prepopup;pop dyn_option_select 'Temp Group'"
However, pressing t during commands like Copy or Move (where Temp Group normally appears in the right-click menu) doesn't trigger anything.
I understand that Temp Group is context-sensitive and only appears during certain operations, but I was hoping it could be triggered similarly to other dynamic options like:
funckey p "prepopup;pop dyn_option_select 'Snap pick to@:@Pin'"
So my questions are:
  • Is it technically possible to assign a hotkey to Temp Group?
  • Is my syntax incorrect, or is Temp Group simply not accessible via dyn_option_select?
  • Are there any workarounds or SKILL-based methods to simulate this behavior?
Thanks in advance!
TRANSLATE with x
English
Arabic Hebrew Polish
Bulgarian Hindi Portuguese
Catalan Hmong Daw Romanian
Chinese Simplified Hungarian Russian
Chinese Traditional Indonesian Slovak
Czech Italian Slovenian
Danish Japanese Spanish
Dutch Klingon Swedish
English Korean Thai
Estonian Latvian Turkish
Finnish Lithuanian Ukrainian
French Malay Urdu
German Maltese Vietnamese
Greek Norwegian Welsh
Haitian Creole Persian
TRANSLATE with
COPY THE URL BELOW
Back
EMBED THE SNIPPET BELOW IN YOUR SITE
Enable collaborative features and customize widget: Bing Webmaster Portal
Back
  • Elecguy
    0 Elecguy over 1 year ago
    This is not possible. Like you said, you can assign a funckey to the Snap pick, but the Temp Group does not have an easy way to assign.
  • excellon1
    0 excellon1 over 1 year ago
    I think it is probably easier to do this with a macro tied to a hot-key but it can also be done using a hot key. Here is an example of using the temp group with move.
    Temp Group needs the command to be pre-selected first such as move etc so have to add the command to the actual hot key syntax.
    funckey m  "move; prepopup; group; pop dyn_option_select 'Snap pick to@:@Symbol Origin' "
    On my system here I hit M followed by the enter key, then select the symbols, then right click "Complete" and lastly left click to move the symbols. Normally with hotkeys
    I hit the key and the command works directly without having to hit the enter key after invoking the hot key, My syntax may be slightly off..
    Maybe try it out to see if gets you closer to what your after.
    Best regards.
  • excellon1
    0 excellon1 over 1 year ago in reply to excellon1
    Here is a macro to move symbols by adding them to a temp group first. Works better than traditional hot key !, easier read too :)
    #Script to Move symbols by adding them to a Temp Group first.
    setwindow pcb
    generaledit
    move
    prepopup
    group
    prepopup
    Select the text above and save it to where your Allegro Scripts folder is located. I use c:\cadence. Save the file as something like move.scr
    In your env file add a hot key to invoke the command for example
    funckey m replay move
    Restart allegro so as to load the updated env file.
    Best regards.
