  3. Add mirrored label on a bottom layer
  • State Suggested Answer
  • Answers 1
  • Views 3825
DK202506181021
DK202506181021 over 1 year ago
Hello!
In a final stage, on the bottom layer - all ref designators are mirrored, which is fine.
If I want to add external label to entire board, it is not. If I mirror it  - it goes automatically to another layer.
Final aim is to export to PDF with label and designators, readable.
Any ideas? (Either display bottom layer mirrored and edit this way, either enter the label and mirror it in the same layer, so final print be readable).
Thanks!
  • KD202502275710
    0 KD202502275710 over 1 year ago
    1. Mirror the bottom layer when exporting PDF
      • Add your label as mirrored text on the bottom layer.
      • In the PDF export settings, choose "mirror layer".
      • This way, everything (designators + label) shows up readable in the PDF.
    2. Use a different layer for the label
      • Put the label (not mirrored) on a documentation layer like Dwgs.User.
      • Export both bottom layer and this doc layer to PDF.
      • Designators stay mirrored; label stays readable.
    3. Use a mirrored image for the label
      • Make a mirrored version of the label in a graphics app.
      • Import it as a graphic onto the bottom layer.
      • It looks mirrored in the design, but readable in the final PDF.
  • DK202506181021
    0 DK202506181021 over 1 year ago in reply to KD202502275710
    Thanks, that was I afraid of :) But your answer confirm there is no easy shortcut for this.
    Yep, just made the needed label in the top layer on the top, the mirror in the bottom and then print the pdf as I want. Working well.
  • Hoangkhoipcb
    0 Hoangkhoipcb over 1 year ago
    Hello DK!
    Do you use Skill?
    You can refer this code.
    Feature of  the Skill : flip  x-direction all text at layer REF DES/SILKSCREEN_BOTTOM.
    axlCmdRegister("flip_design" 'flip_design)
    (defun flip_design ()
    foreach(sym axlDBGetDesign()->symbols
    texts = axlDBGetAttachedText(sym)
    if(texts != nil then
    foreach(text texts
    if(text->layer != nil && index(text->layer "REF DES/SILKSCREEN_BOTTOM") then
    axlTransformObject(axlCopyObject(text ?angle 0.0), ?mirror 'GEOMETRY ?origin 0.0 : 0.0)
    HoangKhoi
  • DK202506181021
    0 DK202506181021 over 1 year ago in reply to Hoangkhoipcb
    Hello Hoang,
    will definitely try it. SKILL is on my future plans, because of automating manufacturing files and printouts export - something I would like to optimize.
    Dimitar Kolev
