  3. Importing parameter file does not change units to mm?
  • Views 3545
MR20250507523
MR20250507523 over 1 year ago
I have set up design parameters, including changing the default units from mils to mm.
I export all these settings to a .prm file.
When I open a new design and import the .prm file, the default units do not change to mm, they stay as mils and all the other param settings are corrupted.
If I open a new design, then manually change the default units to mm, then import the .prm file, all my settings are imported correctly.
Why does importing the parameter file not change the units?
  • JuanCR
    JuanCR over 1 year ago +1
    Hi MR20250507523 . What version and Hotfix are you experiencing this on?
  • DavidJHutchins
    DavidJHutchins over 1 year ago in reply to JuanCR +1
    I replicated the issue using 22.1-2022 S008 and 23.1-2023 S003 The basic issue appears to be the design size & units are not exported to the parameter file... In my test-case design it has…
  • MR20250507523
    MR20250507523 over 1 year ago in reply to JuanCR +1
    I am using 24.1-2024 P001
  • JuanCR
    0 JuanCR over 1 year ago
  • DavidJHutchins
    0 DavidJHutchins over 1 year ago in reply to JuanCR
    22.1-2022 S008
    and
    23.1-2023 S003
    In my test-case design it has the following values from axlGetParam("paramDesign") in the .jrl file
    in Microns:
    (00:00:56) units "microns" xy
    (00:00:56) (-11680.0 -8500.0) width
    (00:00:56) 123340.0 height 130960.0
    in Millimeters:
       (00:03:06)     units "millimeters" xy
       (00:03:06)     (-11.68 -8.5) width
       (00:03:06)     123.34 height 130.96
    however searching the output .prm files shows nothing with the those coordinates, for example:
    C:\Temp\symbols>dir *prm
     Volume in drive C has no label.
     Volume Serial Number is 46E1-12D0
     Directory of C:\Temp\symbols
    07/16/2025  10:02 AM           228,932 np.prm
    07/16/2025  10:00 AM           229,809 op.prm
                   2 File(s)        458,741 bytes
                   0 Dir(s)  63,897,620,480 bytes free
    C:\Temp\symbols>grep -i units *prm
    C:\Temp\symbols>grep 123 *prm
    np.prm:      <blue>123</blue>
    np.prm:      <number>123</number>
    np.prm:      <penNumber>123</penNumber>
    np.prm:      <name>COLOR_123</name>
    np.prm:    <mixedPriority>123</mixedPriority>
    op.prm:      <blue>123</blue>
    op.prm:      <number>123</number>
    op.prm:      <penNumber>123</penNumber>
    op.prm:      <name>COLOR_123</name>
    op.prm:    <mixedPriority>123</mixedPriority>
    C:\Temp\symbols>grep 130 *prm
    np.prm:      <red>130</red>
    np.prm:      <green>130</green>
    np.prm:      <number>130</number>
    np.prm:      <penNumber>130</penNumber>
    np.prm:      <name>COLOR_130</name>
    np.prm:    <mixedPriority>130</mixedPriority>
    op.prm:      <red>130</red>
    op.prm:      <green>130</green>
    op.prm:      <number>130</number>
    op.prm:      <penNumber>130</penNumber>
    op.prm:      <name>COLOR_130</name>
    op.prm:    <mixedPriority>130</mixedPriority>
    C:\Temp\symbols>
  • MR20250507523
    0 MR20250507523 over 1 year ago in reply to JuanCR
