  3. Why does the command extracta -version return the result...
  • Subscribers 160
  • Views 431
Why does the command extracta -version return the result of extracta -versionLong?
ANSYS
ANSYS 1 month ago
When executing the command extracta -version in the Windows Command Prompt (CMD), the program does not return the expected version information. Instead, it outputs the same result as the command extracta -versionLong.
What would cause this issue? How can I get the correct version information with "extracta -version" in my PC?
  • DavidJHutchins
    0 DavidJHutchins 1 month ago
    I can not reproduce your issue when pointing directly at the Cadence s/w trees, as shown below:
    C:\Windows\System32>d:\Cadence\SPB_17.4\tools\bin\extracta.exe -version
    Tool: extracta 17.4-S039
    C:\Windows\System32>d:\Cadence\SPB_17.4\tools\bin\extracta.exe -versionLong
    @(#)$CDS: allegro_batch_sh64 4153571 11/3/2023 Copyr 2023 CADENCE DESIGN SYSTEMS
    C:\Windows\System32>c:\Cadence\SPB_22.1\tools\bin\extracta.exe -version
    Tool: extracta 22.1-S008
    C:\Windows\System32>c:\Cadence\SPB_22.1\tools\bin\extracta.exe -versionLong
    @(#)$CDS: allegro_batch_sh64 4165805 1/15/2024 Copyr 2024 CADENCE DESIGN SYSTEMS
    C:\Windows\System32>f:\Cadence\SPB_23.1\tools\bin\extracta.exe -version
    Tool: extracta 23.1-S003
    C:\Windows\System32>f:\Cadence\SPB_23.1\tools\bin\extracta.exe -versionLong
    @(#)$CDS: allegro_batch_sh64 4178961 3/6/2024 Copyr 2024 CADENCE DESIGN SYSTEMS
    Perhaps you might have a batch file named 'extracta.bat' that is causing this issue?
  • AllegroFlowGuy
    0 AllegroFlowGuy 1 month ago
    Also, Make sure you have the path of the extracta.exe (C:\Cadence\SPB_23.1\tools\bin) in your PATH environment variable.
  • ANSYS
    0 ANSYS 1 month ago in reply to AllegroFlowGuy
    Thanks for your reply. Yes, I have set the PATH environment variable.
  • ANSYS
    0 ANSYS 1 month ago in reply to DavidJHutchins
    Thanks for your test. I only set the PATH environment variable to C:\Cadence\SPB_17.4\tools\bin\, so it should automatically detect the appropriate version.
    Does "extracta.bat" exist for each version? If I have installed 17.2 and 17.4, are there two "extracta.bat" or not?
