  3. Create route-via-shape KEEP-IN from complicated board outline...
  • State Suggested Answer
  • Answers 1
  • Views 3150
Create route-via-shape KEEP-IN from complicated board outline?
DK202506181021
DK202506181021 over 1 year ago
Is there an easy way to create route-via-shape KEEP-IN shape or just add constraint/rule?
My example case is that I have DXF file 2D outline, then convert to Design Outline and then I want to create distance rule for 1mm to board edge for any routing - track, via, shape, etc.
If there is no simple 1mm rule possible, should keepin shape always be drawn manually, or can be automated?
Same question actually stays for define an shape as ground or powerplane...
  • JCTEYSSIER0
    JCTEYSSIER0 over 1 year ago +1 suggested
    Hello, fastest way is to zcopy design outline to route keepin and contacting by the desired value
  • JCTEYSSIER0
    JCTEYSSIER0 over 1 year ago in reply to JCTEYSSIER0 +1
    "contracting", not "contacting Silly to not be able to edit post to correct it
  • JCTEYSSIER0
    0 JCTEYSSIER0 over 1 year ago
  • JCTEYSSIER0
    0 JCTEYSSIER0 over 1 year ago in reply to JCTEYSSIER0
    "contracting", not "contacting Slight smile
